Bad news, the block "failed" ultrasonic testing, just a bit too thin in some spots for the power goal/usage.
Good news, Dale has spare blocks left over from when he had the Super GT car, so we'll be swapping to one of those instead that measures thicker.
Glad it was checked and today I learned you can use 4 seasons lube with these 😅
No description available.
Edited by ActionDan
Brace yourselves, shitty welds are coming...
Dunno how nice this will look with a mig, but do I wanna drop serious coin on a TIG and learn on something so visual in the bay...
Edited by ActionDan
Couple bucks of bunnings finest rubber feet and the tool cupboard fits in nicely.
20220908_195308.thumb.jpg.b2bcc83ee4e844f5a421225607298ecc.jpg304983630_857480655624651_5835300770456952352_n.thumb.jpg.75868694a1591bcfb80ae22e56086ca3.jpg
Tub work has begun in earnest, spent time stuffing around with off cuts to find some settings that worked as I was paranoid about blowing holes in and warping the pieces. The tutorial from ATP shows it being TIG'd, but MIG it is. It also mentions stitch welding, but I wasn't confident I could control the heat well enough so opted to tack it to death and I actually think it looks alright all things considered.
This is the bay side so easy to get to for clean up, the guard side I'll come at from behind to avoid needing to try and do any cleanup in those tight spaces, this was a recommendation by a few people who had done this kit.
I also talking to a mate of mine who does fab/panel work etc and he suggested I should order some weld spot drill bits and attempt to remove the factory panels that way vs just marking and cutting it all out with the grinder, reckons it will make future repairs a heap easier and allow some natural flex in the area if it's plug welded instead.
In my head it makes sense to be as rigid as possible, but the idea of having to cut the entire tub out vs drill out a few spot welds later if I bin it makes a lot of sense.
20220908_204956.thumb.jpg.88b0368d45fbb6e5bf0481f72cc27302.jpg20220908_205851.thumb.jpg.aa3eedaebc2da9fe2127fb4438711570.jpg20220908_205908.thumb.jpg.1f4bcd1c2ee99dd1a7cd4b994016e95d.jpg
Edited by ActionDan
Progress, 1 down 1 to go.
Am happy with the choice to weld the back side of the guard panel, looks fine on the side you will see imo and would've been a pain to clean up nicely. May put a bead of seam sealer down it yet "just incase".
Opted to clean up the up the join to the piece that runs down to the chassis rail, closest to the engine, that will catch the eye and added a bit of strength back into the back of the join just in case given how much I took it back.
Working on inner guard removal, removing shit, finding all my dodgy shit everywhere.
Would love to re-use my old intercooler, how much power you reckon it'd handle at 600x280x76mm. I will try and straighten the fins.
Check out the bent all thread and splitter brackets, car has eaten some ripple strips lol
Bonus pics of old Bunnings "intake" and my dodgy R33 plumb back setup brah
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
