Bad news, the block "failed" ultrasonic testing, just a bit too thin in some spots for the power goal/usage.
Good news, Dale has spare blocks left over from when he had the Super GT car, so we'll be swapping to one of those instead that measures thicker.
Glad it was checked and today I learned you can use 4 seasons lube with these 😅
No description available.
Edited by ActionDan
Brace yourselves, shitty welds are coming...
Dunno how nice this will look with a mig, but do I wanna drop serious coin on a TIG and learn on something so visual in the bay...
Edited by ActionDan
Couple bucks of bunnings finest rubber feet and the tool cupboard fits in nicely.
20220908_195308.thumb.jpg.b2bcc83ee4e844f5a421225607298ecc.jpg304983630_857480655624651_5835300770456952352_n.thumb.jpg.75868694a1591bcfb80ae22e56086ca3.jpg
Tub work has begun in earnest, spent time stuffing around with off cuts to find some settings that worked as I was paranoid about blowing holes in and warping the pieces. The tutorial from ATP shows it being TIG'd, but MIG it is. It also mentions stitch welding, but I wasn't confident I could control the heat well enough so opted to tack it to death and I actually think it looks alright all things considered.
This is the bay side so easy to get to for clean up, the guard side I'll come at from behind to avoid needing to try and do any cleanup in those tight spaces, this was a recommendation by a few people who had done this kit.
I also talking to a mate of mine who does fab/panel work etc and he suggested I should order some weld spot drill bits and attempt to remove the factory panels that way vs just marking and cutting it all out with the grinder, reckons it will make future repairs a heap easier and allow some natural flex in the area if it's plug welded instead.
In my head it makes sense to be as rigid as possible, but the idea of having to cut the entire tub out vs drill out a few spot welds later if I bin it makes a lot of sense.
20220908_204956.thumb.jpg.88b0368d45fbb6e5bf0481f72cc27302.jpg20220908_205851.thumb.jpg.aa3eedaebc2da9fe2127fb4438711570.jpg20220908_205908.thumb.jpg.1f4bcd1c2ee99dd1a7cd4b994016e95d.jpg
Edited by ActionDan
Progress, 1 down 1 to go.
Am happy with the choice to weld the back side of the guard panel, looks fine on the side you will see imo and would've been a pain to clean up nicely. May put a bead of seam sealer down it yet "just incase".
Opted to clean up the up the join to the piece that runs down to the chassis rail, closest to the engine, that will catch the eye and added a bit of strength back into the back of the join just in case given how much I took it back.
Working on inner guard removal, removing shit, finding all my dodgy shit everywhere.
Would love to re-use my old intercooler, how much power you reckon it'd handle at 600x280x76mm. I will try and straighten the fins.
Check out the bent all thread and splitter brackets, car has eaten some ripple strips lol
Bonus pics of old Bunnings "intake" and my dodgy R33 plumb back setup brah
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
