Change to the V band.  Effort is worthwhile.
30mm flares might get you out of trouble for now but wider set would have given you room for future changes.  You're going to need to use tin snips on the guards anyway, and good clearance helps when the fronts move up/down and lock to lock.  Hint - flares to suit 240Z are remarkably close to what's required on these things.
All steps forward though, looking good.
I don't like big flares and 255 is plenty.
The issue is less vband and more T3 manifold. I can run an adapter I guess but didn't want to change manifold just for this turbo when I wanna have it cut up for a ext gate flange anyway.
  • 3 weeks later...
Yep, little flares. Didn't want big ones so had to wait for OS shipping to find some smaller ones.
These:http://www.ebay.com.au/itm/Universal-JDM-Fender-Flares-Wheel-Arch-1-2inch-30mm-4pcs-Wide-set-ABS-Plastic/282457560738?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
As you can see from the pics on the car, they are not huge.
  • 1 month later...
So as with everything, when it comes time to actually do the job, you run into hassles.
Flares were no different so they are not on the car just yet, but progress has been made and hopefully they will be fitted this weekend.
On the back of the flare, you have a right angle mounting surface behind the recessed sections. These will work really well on guards that are very flat, silvia guards, especially the front are very much not flat/right angles to the ground.
In trimming these back to the point where you can get the flare to sit nicely on each guard you basically take that mounting surface out completely so we'll be using Sikaflex as we did with body kit and as seen on most modern car mouldings. Have also marked the guards with the panel beater so we know where they'll get trimmed.
Spoke to Nistune and looked at doco in how they wire in flex fuel capability and could see that with a simple switch, I could give the ECU the 5V input it wants and have dual map capability. The CA ECU has a 5V point you can use that's left over from the removal of bits when the Nistune goes in. I managed to remove the existing wire shielding and solder in some new ones, tested OK.
Have been wiring in some new switches and lights for some other things and have left a littler space on the panel for another switch for a future project.
Next track day is the 26th, I'm hoping to have the flares on so I can use the new tyres, if not can just run the old rubber again as there's still tread on those.
Painful job, but flares and wheels are on, and fouling shit of course!
For anyone that's done it, you know how fun it is working with Sikaflex.
Guards all cut, fronts flared up under the plastic flare, rears cut higher and sealed up.
Inner seam on chassis rail cut back and sealed up and I'm now working through trying to cut/tuck as much of the guard liner as possible to keep some element of protection for the looms, oil cooler, BOV etc.
Also had some scrap metal and some race tape so made a quality radiator air guide, Tucks into the grill nicely.
Edited by ActionDan
So, a grinder, sledgehammer, some self tappers, and cable ties later I have done all I think I can for now in terms of guard clearance.
Folded the seam down at the back of the guard and clearanced the front tub section up. Kept as much of the liner in where it was protecting the loom.
Just need to block up the moroso crankcase evac kit valve to stop that exhaust leak and we're good for Sunday. Car is looking Ricetastic now with 40mm more track.
Forum has disabled media sharing?
Edited by ActionDan
Footage from yesterday is useless as I accidentally aimed the GoPro at the revision mirror so that takes up most of the frame, as does my serious expression. Quality is good though so I'm happy with the new camera setup. Wouldn't mind a better GPS as there's some syncing issues with my older 5hz model.
Anyway, shaved off 2 tenths from the PB and had a class win, won a shirt. That's 3 from 3.
Was a very mixed day with rain all over the place as some interesting groupings (I almost hit 1 guy a few times as he just wasn't watching his mirrors).
First session was wet and the car misfired like a bitch, almost rear ended someone and drove off track to avoid, good times. Coulnd't find the cause of the misfire, but removed and reseated all connections, checked all hoses etc and it just went away 0_0
Second session was dry and clear track so that was the PB. 3rd session I almost hit people again and never got a clean lap then the coolant line to the turbo broke away from the fitting and I couldn't be assed trying to fix it given I was confident the time would be enough and the rain kept coming and going.
Was expecting more from the AR1s, they are wider and softer than the RS-R. I can see in my footage there's time to be had though so I'm confident I'll go faster on them next year, but by that stage I'll have replaced this turbo so it'll be impossible to tell.
I think I ran them too low, about 34psi hot. They seem to want higher pressures but I didn't get a chance to test, also firmer damper settings than I normally run.
Was yet another great day out and a good result for the little CA that can :)
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
