Misfire issue
Hi guys wondering if anyone can lead me in the right direction.
Car is misfiring once hits 10psi, whether it be in low or high boost it misfires from this point.
It is a r33 with built rb25det running 310rkw on high boost.
Car runs up to 25psi.
Changed plugs like for like BCPR7ES and continued with the 0.80mm gap.
The split Fire coilpacks were quite hard to get off but now they seem to go on super easy and off quite easily too once 2 bolts removed of course.
Any ideas as I am stumped?
Cheers
https://www.sau.com.au/forums/topic/469681-misfire-issue/
1 hour ago, JDM33R said:
Did you replaced the coilpacks or just removed them to inspect??
Sounds like coilpacks to me. Misfiring under load.
Hey mate, just inspected. I didn't replace the coilpacks. Just checked it all again and same same, so frustrating
https://www.sau.com.au/forums/topic/469681-misfire-issue/#findComment-7818787
But at what cost
But at what cost
But seriously. If its been running around with the boost feed to the fuel pressure regulator off, and been misfiring under boost, I'd be awful scared of how lean its been running at high load + boost
https://www.sau.com.au/forums/topic/469681-misfire-issue/#findComment-7819038
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
