Intermittent Performance
34R, -9s, e85, haltech etc etc. Approx 350rwkw at 24 or so psi.
Have recently fixed 2 boost leaks (front turbo to TT pipe and IAT sensor on back of plazmaman cooler) but am finding that even after this the "punch" is intermittent, sometimes it's there/good, sometimes it's lacking that extra kick at WOT.
Using onboard haltech map sensor so it stops telling me anything useful after 21psi. No faults being thrown, car has wideband and oil pressure kit also.
I thought it might be intake air temps (pods with an enclosure), as it's been warmer here, but I've had the car feel great and not so great on 27 deg intake temps in the same driving session.
Car is going in soon for cams and valve springs, but if there's anything else I can check, I'm all ears. I've boost leak tested the entire intake tract up to 40psi using a leak down tester.
The difference feels like when I went from airbox and 21psi to pods, better cooler, and 24psi, which was about a 20kw/100Nm gain.
What power are stock GTR bov's good for? Any point in me disconnecting the Mac solenoid for a test?
https://www.sau.com.au/forums/topic/469686-intermittent-performance/
What condition is your electrical system e.g. Alternator output as RB's can suffer voltage drop at mid to high rpm's
type of plugs can make a difference some are better than others if it is a voltage drop.
Check out ADVANCE alternators 150amp as a solution on www.rhdjapan.com they are about $950.00 to $980.00 plus freight.
where does your cold air induction feed from e.g. bonnet, front bar, behind headlight, or intake catch above radiator?
Heat shield between pod filters and engine can help create a cool zone for air pick up.
Was holding off as the upcoming cam install meant I'd likely need less boost for my goal (500rwhp or so).
Can bovs be intermittent​? Am i just clutching at straws there?
Disconnecting boost control solenoid not gonna tell me much is it, other than actuators are fine to standard pressure (1 bar I think)
When we did the pods/cooler it was happier to make more boost so was tuned a few pound beyond the onboard map limit.
Similar to what race pace used to do when tuning beyond max flow of the standard AFMs.
Done on the dyno of course.
Anyway can get a sensor, not a big deal if seeing max boost is the absolute first step.
So isn't this based on an extrapolation of the tune at the max flow of the AFMs assuming that components are the same and behave the same (linearly)?
If you have had boost leaks and turned on Antilag for a while then things aren't the same / behaving the same?
Is a higher PSI MAP sensor equivalent to using Nismo AFMs (in this regard)?
Yep, It was tuned on the dyno at 24psi, on his gauge and using my onboard wideband as a cross reference.
The anti lag is just a couple of tick boxes and were not turned on when it was tuned, it's also off now so it's not a factor.
Wouldn't matter even if it was on as the launch control has nothing to do with what we're discussing here (wot performance) and the rally anti lag only fires between shifts after you lift off the throttle.
What I'm talking about is how much power it's making/how hard you get pushed back into your seat, during full throttle stints.
That doesn't feel consistent currently, but i cant figure out what the variables are.
I thought it might have been purely IAT, as i have pods (shielded yes with cold feed from headlight and inner guard, but still not as well shielded as stock airbox) but the other night out and about for a big Chrysler show locally it was hit and miss with similar air temps.
Have recently fixed 2 boost leaks.
OK.  I've taken a deep breath before saying anything :)
Questions:
1) Is the Haltech controlling boost, or do you have a separate electronic boost control driving the solenoid which CAN see past 21psi?
2) Did you tuner at all oppose this idea of tuning past the MAP sensor's visibility?
3) Did you get the tune looked at after fixing the boost leaks?
Edited by Lithium
lol, deep breathes :D
1) Yes.
2) He said it's best to have the 3 bar sensor but that we can tune past it and see how it goes, I guess this is part of the answer.
3) No, but I'm certain the car would have only had the IAT sensor leak (small), if at all, as the response and power both on and off the dyno after the tune was solid. I only started checking for leaks as I felt the difference in the car. The big leak was the gasket between front turbo and TT pipe connection.
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
