Putting my Rb26/30 up for sale. Assembled and never installed or started, built to improved oem specs
The specs are as follows
Reconditioned Rb26 head to standard specs
Full set of Rb26 engine covers painted in house of kolor candy red - 2pack paint not cheap powder coating
Rebuilt bottom end using excellent condition RB30 series 2 block
New 86.5mm Mahle hypereutectic pistons
New Arp rod bolts
New Jun Crank collar
New Acl bearings
New Rb26 head bolts
New oem Rb26 Oil pump
New oem Rb26 water pump
New timing belt, tensioner and idler
New oem vrs kit
New oem Rb26 headgasket
Fully machined and balance with receipts from PWR Engines -
Remove oil gallery plugs and hot tank block. Bore and hone to suit pistons, surface main face, drill and tap block for O/S head studs. Modify block for idler (Rb26 head on Rb30 block).
Clean, crack test and grind crank .025. Machine crank for oil pump drive, drill main oil feeds.
Clean, crack test con rods, fit arp rod bolts and resize
Balance motor
$6500 Firm
Please contact me via pm if you are interested. Engine is located on Brisbane northside
Cheers
Edited by Gts-t
https://www.sau.com.au/forums/topic/469694-rb2630-for-sale/
I do want this sold so if anyone is interested let me know and well see what we can work out.
I also have basically a complete stock R33 gtr hot and cold side, 34 gtr intercooler, all pipework and all bov pipework, starters, alternators etc
https://www.sau.com.au/forums/topic/469694-rb2630-for-sale/#findComment-7819267
