11 hours ago, iruvyouskyrine said:
How much was the dynamat?
$210.00 off eBay, theres another brand where you get a little bit more for $20 dollars less, but i'll stick with the brand that's been around a while.
i always thought it was more expensive than that. Might be worth getting some for my daily. It has no sound deadening and shakes and rattle like nothing else!
Yeah I thought it was super expensive too until I had a look on eBay.
Well I’ve got one sheet left of the 9 sheet pack and this is what I’ve got done so far, just got to put it on a few more fiddly places then the floor is done.
Ordered an amp and speaker wire kit too, gonna tape all of it down to the floor prior to sticking the carpet and interior back in so it can all stay in place for future upgrades. Thinking about getting some 6.5” component speakers and a 10” sub and amp in the boot. Forgotten what music sounds like in this car with the original speakers having more holes than Swiss cheese!
10 hours ago, CRSKmD said:
Did you happen to weigh the stuff before putting it in? Have heard it has some heft but does a really good job for sound deadening.
It said 8.9Kg's on the box, i'm sure i've read somewhere else that the original sound deadening weighs 13kg's. Don't really know what to believe though as i'm sure the original sound deadening doesn't cover anywhere near as much as what i have just put back in. Either way, i'd rather be able to hear and speak in the car than hear absolutely everything that's going on outside and deal with heaps of vibrations.
1 hour ago, vxsr33 said:
Nice progress so far.
I would also prefer the sound deadening, 8.9kg isnt much and i would assume the dynamat would work better than the old factory stuff.
Thanks, Yeah im sure it will do a miles better job, apparently this stuff is good for keeping temperatures down too. I suppose every little helps when you don't have air-con :down:
Wiring kit arrived yesterday, so I made a start on feeding the speaker wires from the doors through to the boot, then fed the power cable through a hole in the firewall.
Once I’d done that I put two RCA’s from the centre console and ran all the wires along the transmission tunnel.
Whilst I was doing the wiring I got a 6mm power cable with an in-line fuse fed through which I’ll use to power the fuel pumps as the standard wiring won’t be up to the job.
And then finally I got to chuck the carpet back in!
I’ve also managed to get the door locks out of the old car, I’ll be chucking these into the new car tomorrow I reckon. Then I can throw the door cards back on.
And then it’s just putting most of the interior back in place and freeing up more space in the garage!
Nice work with the dynamat, must feel good replacing the factory stuff with newer fresher stuff.
I removed all the sound deadening from my 32 sedan, sometimes regretting it. I guess I could always do what you've done.
Cheers, the previous owner removed all the factory sound deadening so this was the only real option for me. I’d have left the factory stuff in personally.
A 9 sheet pack will do the floor, and I still have a little bit of a sheet left to stick a bit behind the component speakers when I get to round to buying some.
So i managed to get a few jobs done this weekend,
First up, i got the door locks out of the old car and into the new one, little bit of fumbling around to get the circlips out, but apart from that it was mainly hassle free.
i then proceeded to stick most of the front half of the interior back in, i'm keeping the air/fuel ratio gauge and oil pressure gauge out for the time being until i decide where i want to mount them. the boost gauge will also need a permanent home as it is just laying on the passenger floor for now. they were originally housed in some makeshift gauge holder where the centre vents sit, but i want something a bit more driver focused this time around.
I also need to stick the plastics on around the steering wheel and underneath the dash, i need to swap out the steering wheel boss and indicator stalk though, as some wires have been cut. so i will install them plastics once i remove the boss. gonna make a remover at work out of some scrap flat bar and a welded nut, i'm only gonna use it once so no point buying one.
Once all that was done i set about changing the brakes over from the old car onto the new, (the discs are cracked on the new car so thought i might aswell get some more use out of the old ones). Also snapped a pic of the coilovers, they are literally brand new which is good to see!
Old Brakes:
New Brakes changed over, yes the discs have surface rust, but only because they've been sat for a while:
I also thought id fit the uprated front sway bar that came with the new car while the front end was lifted up. unless im missing something, i dont see how this new one will fit, and i cant find any information about a 30mm front swaybar for the GTS-T so im presuming its an S13/14 item or something. and i'll also need some D-clamps to make it fit.
comparison between old and new:
So i chucked the standard sway bar back on and lowered the car back down to the ground.
Moved onto the rear end, noticed the new car had a hicas lockout bar, and still has all the hicas stuff in the back, im gonna rip all this out and fit the eliminator kit from the old car. so i set about taking the rear hubs off the old car as these ones already have the tie rod ball joints taken out. Also got a nice suprise when i took the rotors off, turns out theres Project MU handbrake shoes in there!
I also thought id throw in all the adjustable arms that came with the new car, i did fit the lower control arms, but didn't like the fit, so chucked the original ones back in.
I've still got to reassemble it all, but will do that tonight. then move round to the passenger side and do the same again. Slowly ticking jobs off the list!
  • Like 3
  • 1 month later...
Not much of an update with regards to progress on the car, struggling to find time these days to get anything done apart from work!
I managed to finish the rear end off, got all the adjustable arms fitted and the Hicas lockout bar in place, also removed all the Hicas lines from the car.
And the rear calipers are on too. Brakes just need bleeding, but this will have to wait till the engine and gearbox are in place.
Also got the steering wheel on and tidied up the remaining wiring so the interior is pretty much complete.
I also needed to buy a "sensible daily" as my housemate is getting rid of the car i'd been borrowing while the skyline was off the road, so here she is.
Hoping i can get some time in the next month or so to finish the skyline off. If not i'll probably put it all up for sale so someone who has the time can actually finish and enjoy it as i hate seeing it sat doing nothing!
Hopefully some updates will happen in the very near future!
  • Like 2
5 minutes ago, PranK said:
Damn that suspension looks great!
Damn I want an Evo! :)
Im sure the wheel alignment place will have heaps of fun when it finally goes for an alignment, at least it looks nice :4_joy:
Yeah the evo is really fun to drive, its nice to have air con and be able to fit 4 adults in a car comfortably too!
  • 1 year later...
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
