R33 Headlights questions
Hello all.
After a few minutes of search on the forum, I don't find some informations thath I need (or I don't used right keywords).
My questions are:
1: What are differences between R33 headlights spec1, spec2 and spec3? what differences? they are all compatible on all r33? or the mounts change?
2: For the Xenon and Hid Headlight, the headlight level is automatic or manual electronic? (if you have high load on the trunk, it corrects the level automatically?)
3: For the Xenon, someone has the dimensions? (like that: https://hidkitpros.com/wp-content/up...dimensions.jpg
Thanks a lot
Greetings from Switzerland
https://www.sau.com.au/forums/topic/469719-r33-headlights-questions/
Link doesn't work
Don't put HID kit in your halogen headlights. Don't put LED kit in, they're all shit.
Series 3 GT-R came with factory xenon/HID (bulbs starts with D, not H) http://www.kudosmotorsports.com/catalog/headlight-xenon-nissan-skyline-series-021997-p-534.html
See:
Make sure the (outer) headlight lenses are clear. Use a headlight restoration kit if they are hazy/yellow. Any hazing will reduce output. I think the R33 uses H1, so don't have much of an upgrade besides Osram nightbreakers/Philips x-treme vision. Make sure you aim them properly.
Not sure on the level adjustment, probably not auto/self levelling.
Do a retrofit! It isn't as hard as it seems. Your end result will be so much better.
7 hours ago, niZmO_Man said:
Link doesn't work
See:
Thanks a lot for all those infos.
My problem is that I have to convert my headlights to LHD, and if I want to stay with Xenon Headlights, they must have headlight washers and auto/self leveling ajdustement.
9 hours ago, niZmO_Man said:
How strict are they at checking cars when you drive around? You might be able to get away with a Morimoto Mini H1 (switch the bulb to halogen during inspection time).
90's Skylines are RHD so...
With this kit you can use full halogen or HID?
Some other questions, I could preserve the Xenon Headlights, but i can't exceed 2000Lumen.
Some one know how can I do that? What bulb use with stock Xenon headlights?
The morimoto mini h1 are direct replacement on the xenon headlight of R33?
They are really strict.
Or it is possible to have xenon or hid kit with maximum 2000lumens?
I saw that there is hella projectors with magnetic leveling. Maybe its ok but I cannot find that.
No not direct fit. Retrofitting is opening up your headlights and mounting projectors in there. Work can vary quite a lot (read: lots of effort), especially on reflector headlights.
I think you should forgot about those cheap HID kits and focus on improving your current setup. Clear front lenses plus bulbs like the Philips X-treme vision.
OE series 3 GT-R is D2S I believe.
I think you'd be after the 25W D5S/D6S/D7S/D8S, which are supposed to be 2,000lm and not require self levelling/washers.
The point I'm making is, the H1 reflectors are designed for H1 bulb as light source, no benefits gained from throw in anything besides H1 bulbs, if you're after actual performance upgrade. Retrofit projectors from an Audi or something with the 25W HID projectors, or LED projectors from something like Prius V.
Nice info mate.
Opening the headlight it's not a problem.
I can replace the d2s with the d5s directly?
I would rather prefer having projectors that reflectors, because it's easy to convert to lhd pattern.
Led projectors? Sounds nice. Do you have other infos about that?
Yeah, replacing projectors isn't a big thing, usually easier than working with reflectors. I have no idea what sizes/shapes the D5/6/7/8 projectors come in, too new for me :P.
LED projectors are another thing you can try, if you can find. I recommend the Koito bi-LED, such as found in Prius V, and other cars like Murano. You'd have to look at wreckers/junk yards and second hand parts places like that. With LED you can usually wire them up easily and not worry about bulbs.
I actually have a bunch coming from Japan, so will see how they go in R32 headlights :D
I'd probably be easier to find 25W HID projectors and fit them into your current headlights. This will require lots of work so I recommend getting a second pair of headlights (doesn't have to be Series 3 HID ones).
But yeah, let us know what you find.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
