Can you use polish on small rust spots?
I've got a very small rust spot on my car, no bigger than 1-2mm that just recently started to rust after i accidentally scratched it a few months ago., I saw a youtube video saying that you can just get polish to remove the rust by wiping down on it hard. I also had a friend tell me to wipe it hard with vinegar, but is that safe for the paint around the stratch? Also if i dont treat the rust, will it just continue rusting from underneath the paint from the areas surrounding the rust? Ive already bought touch up paint but im not sure the best way to remove the small rust spot without f**king the paint. thanks.
Next time you touch up any bare metal straight away.
Yes it will continue to rust until it has rusted all it could rust.
Usually you sand it. But you can try a coarse polish. Might work or might not.
If it doesn't then a easy fix is get a rust converter. Then paint over it.
sand it back, say 200 [if your rust is really bad] then 400 then 800 then 1200 grit emery, don't rush, take your time.
Then paint it, mask off, primer, undercoat then colour.  Let it dry for a few days then cutting polish and then polish to blend it in.
or just use a converter then kilrust and it will fix it but it will look like sh1t!!!
Or drive to the nearest panel beater shop.... by the time you buy emery, converter, primer, paint, and all the other stuff, plus time etc it will probably not be that much different.
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
    • Seriously though, it's the Shaft Autoservice high mount rear spoiler: https://az-style.shop/items/5ffaad5a72eb464137a6edb1
