ruinned Posted March 23, 2017 Share Posted March 23, 2017 Car Misfiring after a big rainfall. Hey everyone, So being having alot of rain lately but last night was a big heavy one, got in the car this and headed to work a few blocks away the car started misfiring and stuttering. wouldnt rev higher then a couple thousand. it is the second time this has happened after a large amount of rainfall. any ideas on what it could be ?? no check engine light comes on either. Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/ Share on other sites More sharing options...
GH05T Posted March 24, 2017 Share Posted March 24, 2017 electrical problem somewhere, something got wet. sounds like a coilpack issue though Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7819666 Share on other sites More sharing options...
ruinned Posted March 24, 2017 Author Share Posted March 24, 2017 Yeah going to pull it apart this afternoon and find what is getting wet. Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7819671 Share on other sites More sharing options...
GH05T Posted March 24, 2017 Share Posted March 24, 2017 do you have bonnet vents? Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7819698 Share on other sites More sharing options...
mighty190 Posted March 24, 2017 Share Posted March 24, 2017 If you have a sunroof, the drains may be blocked and water can leak in around the passenger footwell and the ecu can get wet Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7819700 Share on other sites More sharing options...
ruinned Posted March 24, 2017 Author Share Posted March 24, 2017 13 minutes ago, GH05T said: do you have bonnet vents? Nah no bonnet vents, my drive way points down tho so the car parks at a slight angle. so water might drip down that way. 4 minutes ago, mighty190 said: If you have a sunroof, the drains may be blocked and water can leak in around the passenger footwell and the ecu can get wet i have a sunroof, i will def check that out. Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7819702 Share on other sites More sharing options...
Sinista32 Posted March 24, 2017 Share Posted March 24, 2017 also clean your AFM. Sometimes moisture gets in if your running a POD 1 Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7819703 Share on other sites More sharing options...
ruinned Posted March 24, 2017 Author Share Posted March 24, 2017 12 minutes ago, Sinista32 said: also clean your AFM. Sometimes moisture gets in if your running a POD Most likely this, the filter that came on the car was a mushroom pod filter one and noticed the other day that it was in a real bad shape. got a new filter on its way. Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7819710 Share on other sites More sharing options...
mighty190 Posted March 24, 2017 Share Posted March 24, 2017 If there is water around your ecu the easiest way to check if the sunroof drains are blocked is just pour a small amount of water straight down the drains and see if comes out to the ground. If it is blocked you can sometimes just blow compressed air down there to free the blockage Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7819712 Share on other sites More sharing options...
niZmO_Man Posted March 24, 2017 Share Posted March 24, 2017 22 minutes ago, ruinned said: mushroom pod filter There's your problem Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7819724 Share on other sites More sharing options...
ruinned Posted March 24, 2017 Author Share Posted March 24, 2017 1 minute ago, niZmO_Man said: There's your problem Have a new non mushroom pod filter on its way Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7819725 Share on other sites More sharing options...
LaurelPWR Posted March 24, 2017 Share Posted March 24, 2017 I have the same problem on my rb25 s13 when I drive it in rain... It's moisture getting in through the cooler pipe hole in the guard and the front of the car and being sucked up by the pod ... I even had a small puddle in my cooler once and another time, just recently, I could see moisture droplets in my clear breather lines going from my cam covers to my air oil separator and back into my intake.......E85 doesn't help this situation either hahah Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7819744 Share on other sites More sharing options...
JDMgirl90 Posted April 6, 2017 Share Posted April 6, 2017 I had the same issue with my 33 every time it would rain. It turned out that the pod filter wasn't sitting right and was actually sucking in water. I moved it down and haven't had a problem since. Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7822558 Share on other sites More sharing options...
GTSBoy Posted April 6, 2017 Share Posted April 6, 2017 Bah. f**king pod filters. My R32 has a 100mm PVC pipe with forward facing bellmouth behind the brake cooling opening in the front bar, direct into the standard airbox. Has never given a moment's problem even in torrential rain. 1 Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7822579 Share on other sites More sharing options...
tridentt150v Posted April 8, 2017 Share Posted April 8, 2017 Funny, I have a mushroom pod filter with a Perspex CAI, and not a problem. Link to comment https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/#findComment-7822880 Share on other sites More sharing options...
