Car Misfiring after a big rainfall.
Hey everyone,
So being having alot of rain lately but last night was a big heavy one, got in the car this and headed to work a few blocks away the car started misfiring and stuttering. wouldnt rev higher then a couple thousand. it is the second time this has happened after a large amount of rainfall. any ideas on what it could be  ?? no check engine light comes on either.
https://www.sau.com.au/forums/topic/469741-car-misfiring-after-a-big-rainfall/
13 minutes ago, GH05T said:
do you have bonnet vents?
Nah no bonnet vents, my drive way points down tho so the car parks at a slight angle. so water might drip down that way.
4 minutes ago, mighty190 said:
If you have a sunroof, the drains may be blocked and water can leak in around the passenger footwell and the ecu can get wet
i have a sunroof, i will def check that out.
12 minutes ago, Sinista32 said:
also clean your AFM.
Sometimes moisture gets in if your running a POD
Most likely this, the filter that came on the car was a mushroom pod filter one and noticed the other day that it was in a real bad shape. got a new filter on its way.
If there is water around your ecu the easiest way to check if the sunroof drains are blocked is just pour a small amount of water straight down the drains and see if comes out to the ground. If it is blocked you can sometimes just blow compressed air down there to free the blockage
I have the same problem on my rb25 s13 when I drive it in rain... It's moisture getting in through the cooler pipe hole in the guard and the front of the car and being sucked up by the pod ... I even had a small puddle in my cooler once and another time, just recently, I could see moisture droplets in my clear breather lines going from my cam covers to my air oil separator and back into my intake.......E85 doesn't help this situation either hahah
I had the same issue with my 33 every time it would rain.
It turned out that the pod filter wasn't sitting right and was actually sucking in water. I moved it down and haven't had a problem since.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
