Gasket for coil pack cover ?
Hey everyone,
So started pulling apart the engine to change the spark plugs and what not.
Notcied that the gasket/rubber on the cover over the top of them is pretty hard and not the best looking.
Want to find a replacement gasket for it but i cant find one any where
Where would i find one ?
https://www.sau.com.au/forums/topic/469764-gasket-for-coil-pack-cover/
Is there even a gasket?  I can't remember ever seeing or caring about one on any RB engine, and I cannot see any reason why there would need to be one either.  I mean, let's face it.  if I've had the coil cover off of RB engines that many times and I can't even remember whether there's a gasket or not, then there's probably not one!
There is a rubber lining on the underside edge, whether you can get a replacement without changing the whole cover I'm not sure.
Just ditch the cover, your coil packs will thank you for running cooler.
