Gtr 34 series II 08/2002
EOI is my 08/2002 WV2 sparkling silver gtr series 2 non v spec skyline. Carbon fibre front lower lip, top secret carbon fibre rear diffuser, carbon fibre high wing stands, stock unmodified engine and drivetrain, immaculate inside and out, serial number is 14th last r34 gtr built on registry. Only extras is carbon pieces, wheels, hks hypermax coilovers , nismo side skirts and floor mats. Immaculate unmolested. Looking for around 80k have all books, keys and paperwork. Please don't call please text 0427459312
Edited by V8etr
More picture
https://www.sau.com.au/forums/topic/469781-gtr-34-series-ii-082002/
7 hours ago, Hadouken said:
Someone Nissan fast the vin
5 hours ago, V8etr said:
Check the serial number on gtr registry ,14th last 34 built
Confirmed on GTR Registry. This is the 14th last built of the R34 GTR Series 2 Non V-Spec.
BNR34-404413 GGJPRVYR34ZDAAGX-D GTR (Series 2) 2002-08 WV2 Sparkling Silver
Privacy Glass GTR (Series 2) #1254/1268
  • Like 3
On 3/29/2017 at 5:26 PM, UWISSH! said:
Shouldn't a 2002 model have the black interior?
No the darker interior applies to the V-Spec II or V-Spec II nur variation, not the model year.
There were regular (ie, base model non-vspec, m-spec, nur etc) 34 GTR's built all the way through the 1999 - 2002 period.
  • Like 1
Pretty sure it's "All" series 2 R34 GTR's that came with black seats no matter what designation - standard/vspec etc.
Have seen plenty of Auctions of standard series 2 year 2000 and above with black interior.
  • Like 3
V Spec II's were made from October 2000 onward, so that might be what you're seeing. You may have been able to option the black interior into a standard GTR, I'm not sure. As far as I know the grey interior was standard in regular R34's regardless of the year. Just like the leather interior was exclusive to the M-Spec, the black interior represented the V-Spec II.
I dug a little deeper and can't seem to find a definitive answer. There are some with grey interiors, and some with black. It's very strange. The only thing I can think of is if you bought one post October 2000, you were able to choose?
All series 2 cars (VIN 400001 and above, plus any of the 17 VIN with 010xxx) have black seats, with the except of the M-Spec and M-Spec nur which have black leather seats. These cars started August 2000. Also there are no V-Specs after this date. The grey seats in the car above aren't factory fitted. It also looks like it has the black door trims although it's a little hard to see.
  • Like 1
  • 1 month later...
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
