M35 torn inner CV boot and rear subframe question
Hi guys - hope you're all well!
Loving my PNM35 so far and finding for the most part it's been quite reliable and easy to maintain. Just run into my first proper problem though with a torn front inner CV boot. Has anyone fixed these with aftermarket before or is it best to get the Nissan part? Is it the same part as the rear inner CV boot?!
Also attached a few pics of my rear subframe. I've noticed when I jack up the car the rear subframe moves down quite a lot - is this normal? I didn't want to go wrenching on it to try and tighten it right up if it's meant to have this kind of movement but it seems like an awfully big gap.
Other than recently replacing my rear calipers it's just been basic maintenance and I've just got the odd suspension squeaks and rattles to hunt down. Either loose top mounts on my rear shocks or worn anti roll bar links or bushing I'm thinking.
Ah right - I did wonder if there was meant to be another rubber bush above? Don't think there's one on the other side either. I really need to get under and check the forward points to see what's going on there.
Pretty sure my rear diff mount is knackered as it has the telltale trickle of oil down it...wonder if that's because it was under added stress.
  • 3 weeks later...
the vertical movement in the subframe bushes is normal. ive recently fixed that with some whiteline subframe bushes. sod of a job but well worth it. plenty of extra road noise and vibration, but makes for a solid rear end.
  • Like 1
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
