So I've gone to get an alignment and long story short they ballsed it. The only useful thing they could show me was that the amount of space between the front tyre and front bumper is different on the left to the right. So with the same caster setting I will have, eg, 3 fingers width from front tyre to front bumper on one side and 4 fingers on the other.
Why is this? I haven't had any accident or big hits that I can remember.
So the real questions it, what can I do to fix it so that its balanced each side. I believe it may have to do with the front subframe? But I don't know what could be out of balance or what to adjust so that this is equal. Note this isn't something which an alignment will fix, as it can be aligned equal on each side, but this condition will still occur.
1 hour ago, blind_elk said:
Caster is measured in degrees, not fingers.
Really? I did not know this...
As mentioned the problem is that one tyre is rubbing against the front plastic inner guard while the other doesn't.
and If I am to use Mr Hammer, where are you suggesting I use it?
I get that you probably think everyone is not being that helpful, but basically everyone deals with this sort of issue in the same way. Its actually the body that is in the wrong place compared to the wheels, so you fix where the body is. It is perfectly normal for medium to high caster to rub on the inner guard liner, it is fixed by removing the inner guard liner.
after that it will hit the lip on the guard which you fix with a guard roller (or hammer if you prefer...)
after that it will hit where the front bumper joins the guard which requires angle grinder on the guard and bumper and holding it on some less intrusive way like drift spec cable tie stitches
after that you are trying to get too much camber for a stock body, time to change the uprights and control arms.
  • Like 1
But.... but...
Is it normal on R33's that one wheel is in-front of the other, and can have much less Castor before it starts hitting things?
Pretty this is what OP is trying to explain here
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
