1993 R32 GTST, RB30DET, 281 RWKW + Mods
1993 R32 GTST M-Spec, Owned since 2004 @ 128,000km....Current km ~175,000km
PRICE: $10,000 ONO  CONTACT: 0401 317 009 (David)
ENGINE
RB25/30DET (R32 RB25DE head, RB30E series 2 block)
CP 9:1 Forged Pistons
Spool 4340 H Beam Rods
ARP rod fasteners
ACL Race Series main bearings
ACL Race Series big end bearings
ARP head bolts
Cometic MLS head gasket
refer to - http://www.spoolimports.com/spool-engine-rebuild-kits/nissan/rb30det-rebuild-kit/holden-nissan-rb30det-dohc-rebuild-kit-with-cp-forged-pistons-9-0-1
This motor probably only has about 7000km on it from when it was built in 2011.
Garrett GT3076R 0.82 A/R Turbo
3 inch metal intake pipe to turbo
Trust VSPL FMIC
Blitz DSBC Dual Stage boost controller (Low boost ~15 PSI, High Boost ~19-20 PSI)
Q45 AFM
Bosch 550cc Injectors
NisTune R32 RB20DET computer with map to suit above setup on BP98
Bosch 040 fuel pump
Nismo adjustable fuel regulator
3" Turbo back exhaust (Bell mouth style dump to suit GT30 to Catalytic converter to resonator, to JUNBL rear muffler)
I have parts of a replacement exhaust system which would quiet it down a little more which I'd throw in.
Power - makes 281 RWKW on Jaustech's dyno (can attach dyno plot)...240 of those RWKW available from about 4000RPM.
Could crack the 300 RWKW with bigger injectors and a Z32AFM.
DRIVELINE
RB25GTST G/box (std internals)
Nismo engine mounts
Nismo gearbox mounts
Jim Berry "race" clutch (reasonably light on the foot, but does bite hard)
OEM flywheel
Modified RB20 GTST tail shaft (w/ RB25 yoke) to suit gearbox and diff
STD OEM V-LSD diff (I have an R34 RB25 Neo torsen differential at home which is easy to fit up...just needs backlash to be setup)
STD OEM driveline otherwise (more than adequate for the power output)
SUSPENSION
Full Sydneykid Bilstein/Whiteline setup (http://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/):
Bilstein B4 "c" clip height adjustable shocks valved to suit suspension setup
Whiteline "lowered" (25mm lower than stock) springs
Whiteline front and rear fixed anti roll bars
Whiteline front upper camber arms (adjustable)
Whiteline front adjustable castor bushes
Whiteline rear camber arms (outer IIRC)
Volk Racing GT-P's (old school) 8" fronts, 9" rears IIRC (they came with the car back in 2004)
Bridgeston Adrenaline RE001 235/45/17 fronts and rears IIRC
Not fitted but will chuck in -
Whiteline HICAS elimination kit
Whiteline subframe replacement bushes (NOT PINEAPPLES)
Superpro diff bushes
Superpro steering rack bushes
few other odds and ends which I have accumulated over the years
BODY
Genuine R32GTR front bar (will throw in the OEM mesh that goes over the intercooler)
R32 GTR rear wing
R32 GTR rear boot
Will throw in: GTR style fibreglass side skirts (in primer)
R32 GTST boot/wing
Issues - one of the rear quarters has a sizeable dent in it about the size of a football and about as deep as a book (thickness). I have been quoted about $600 to fix it and paint. The boot also has a small dent in it also. IIRC I was quoted about $1000 (maybe a touch more) to fit the side skirts, fix the dents and paint. Will post photos when I get a chance.
MISC
R32 GTR centre console tripple gauges (not connected)
Alpine head unit
GReddy turbo time (not connected)
Viper (unknown model) immobiliser
Not fitted but will throw in:
Focal 6.5" front splitters (cost me $500 at the time and never fitted)
Alpine 4 channel amp
wiring kit to suit the above
Viper immobiliser (remote start capable, few other features)
There's probably a few other things I've missed out but that will do for now...
Reason for selling - I cannot economically justify owning it anymore!
Pictures are located here -
  • Like 2
https://www.sau.com.au/forums/topic/469799-1993-r32-gtst-rb30det-281-rwkw-mods/
really nice choice of motor setup. Is this engineered for this motor? Or will the buyer need to put back to a RB20 for RWC? Just thought i'd ask the question.
Had a few questions which I thought I'd post the response:
Straight? Has it had any accidents? Repaired damage etc(other than that stated in you post)
No major accidents.
Only accident repair that I have had was relatively minor damage caused to the front bar/bonnet as a result of a driveway collision. The Bonnet was repaired and the front bar and reinforcement bar that were scrapped and replacement items fitted.
Any rust?
On the roof there is a tiny spot the size of a ball point (from a pen). You would barely noticed it if you tried looking and didn't know the car. It appears to be surface rust.
On the damage (stated in the post), where the object has contacted the panel, there is a small amount of surface rust. If I wanted to, I could remove it...however this would only be a temporary fix.
Engine
Was it built by a professional builder?
Yes - AutoSolutions and Restorations was the assembler. Majority of the engine work was done by Lewis Engines
Was the crank machined and grub screwed etc? Larger crank collar drive for the oil pump fitted?
Yes and Yes. For reference, it has an RB25DET S2 oil pump fitted (the one with the larger drive area from memory)
Oil restrictors fitted to the head? And rear head oil drain?
Yes - as per the RB30 guide and RB30 thread based on it being a street car.
Oil head drain -
Yes, drained back to the baffled/winged race sump via a 1.5-2" (approx.) flexible hose.
have you head any issues with the engine? Erroneous Knocking etc?
Initially we had issues being able to wind timing in it without it knocking - see below post:
End result was it just needed a bit more work in the tune.
Erroneous knocking - was found to be the old knock sensors triggering under light load. Solution was for the ECU to ignore the knock sensors (install a resistor inside of the ECU) and the tuner used knock ears and tuned very conservatively.
Be aware, like a lot of forged builds, there is some piston slap especially when cold. With the hood down, inside the cabin, you can "just" notice it from time to time. But it's best to hear in person.
was the turbo new?
No - was off a forum member Cubes (Joel) here in adelaide. Was stored meticulously by him (and I) until it was installed onto the car. Not sure of km done by Cubes, but I rebuilt the motor at around 168000km and it now has in the high 170000kms (can't remember actual figure).
standard cams?
No - Tomei 256/8.5mm cams on both the intake and exhaust.
Do you have any regrets, or things you would have done differently with the build?
To be honest, for the power, I could have probably got away with a standard RB30 bottom end and a conservative tune. Sure it wouldn't have made as much power, or be quite as responsive (lower static CR), but it would have been cheaper and given me 90% of the result.
The power figure seems on the low side.... What boost was that on?
See attached dyno graph.
As per above, tuner was very conservative with the tune.
any other issues with the car? Electrics not working? Air con not working? Etc. etc.
Aircon - havent used it in a while so probably doesn't work.
The GTR triple gauges are not hooked up (it was more to fill the DIN void)
Oil pressure sender (and therefore oil pressure gauge) occasionally will cut out. Engine has been verified multiple times to have correct oil pressure.
  • 6 months later...
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
    • Cheers, yeah it was recently imported, is the actual Nissan not an Infiniti so will have to do some chasing around for parts.    Any ideas if the side skirts from a Q50 would fit on the 400r?
