23 minutes ago, Hadouken said:
I don't think tomei ti has step downs.
It's balls loud.
The end
I had a good look over an Evo one at hypertune one day. Nug rear muffler. Lost the photo though.
Either way it crazy loud.
  • Like 1
the r32 gtr one is 89.1mm (no restrictors in the resonator or the rear muffler), but drops to 80mm at the cat flange. I got mine modified to be a true 3.5 inch all the way
Titanium looks cool and is very light
Sounds pretty good in my opinion.
Edited by Darmanin10
  • Like 1
TI is sexy and light. Sound is your choice so youtube the ones your keen on. Lads like em loud which isn't y cup of tea.
I run the HKS Super Turbo system, which after many jap brand systems, this one is by far the best for my needs. Passes RWC/RTA inspections. Opens up to a very nice note after about 3300rpm.
Custom is fine for 3.5 inch and upwards, flows best for large power applications. As for not being deflectable depends on DB's @ 3000-3200 rpm
  • Like 2
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
