1994 R33 GTS-T
1994 S1 R33 GTS-T
Owned for 16 years
122000 kms
Under cover garaged the whole time
Exterior
GTR Bodykit
Polished perforated aluminium grilles with custom projector halogen spotlights.
Black respray in 2001, paint work still mint.
Interior
Panasonic head unit.
Fusion splits in front doors and 6 x 9s in rear sides
4 Channel amp and slim sub in boot.
Pod Gauges
Recaro Replica racing drivers seat- really comfotable even on long drives
Factory seat included.
Nice velour interior mint condition.
Braking
R33 GTR Brembos front and back
Braided Lines
Greenstuff pads
GTR master cylinder
Wheels and Tyres
Rota P45R Bronze
Mildly stretched Kuhmos for agressive stance
Suspension
Sydney Kid Road kit
Whiteline sway bars front and back
Whiteline bushes
Whiteline Springs 25% stiffer than stock matched to Bilstein shocks
20mm lower than stock
Transmission and Clutch
Manual
Series 2 Gearbox
Nismo Pro TT 1.5 way LSD
Heavy duty clutch
Hicas Lock out bar
Engine
RB25/30 built by TweakIt
20000 kms
3.0l forged bottom end
256 deg Poncams
Garrett GT3076R 0.82 A/R internally gated
Siemens 570 cc injectors
Polished Plazmaman inlet plenum with 72mm throttle body
Haltech Platinum Sport 1000 ECU
Full sequential ignition
N1 Oil Pump
337 rwkw on 98 with 21 psi
Cooling
75mm front mount intercooler
Exhaust
Three Inch Jasma from Japan with 5 inch tip
Stainless steel
Air Con
Recently fitted new condensor, all filters etc
Freezing cold.
Window Tinting
Semi-reflective tint.
Security
2 point remote alarm
Plus Black Widow FOB immobilser
Plates
GRR-33R Included
$21,000 Neg but not much
https://www.sau.com.au/forums/topic/469824-1994-r33-gts-t/
  • 5 weeks later...
  • 3 months later...
  • 3 weeks later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
