Radiator upgrade
Radiator upgrade
Ok so i have always had some problems with the cooling system in my r33 GTS-T, even before i reinstalled the turbo, but now that i have it seems the the condition has become much more frequent (note i have a massive, not my choice, front mount on the car and can only assume that it must be helping the problem, when the car overheated when N/A the front mount was still installed). the latest time has got me thinking about replacing the radiator completely so the engine has more room for error, i cannot find leaks anywhere and i have seen the water boil past the cap valve so i assume this means that the system is capable of holding atleast a little pressure (i have replaced the cap incase that was the reason aswell).
So my main question is there a decent-ish aftermarket upgrade for around $300, i have seen people rave about koyos but they all seem to be out of my price range, so far i have found
http://justjap.com/cooling-pro-alloy-radiator-nissan-skyline-r33-r34-stagea-rb25-rb26.html which is around $250 shipped
or
http://worleyautoparts.com.au/product/alloy-radiator-for-nissan-pintara-skyline-r33-r34-auto-manual-1993-2003-atmt/ for $150
basically i would just like to know your opinions on what the problem could be and/or any preferences on the brand of radiator for relatively cheap.
Cheers
the water pump seems to be fine, the water definitely circulates through the system.
the radiator has no massive dents in the fins but the coolant has become murky rather quickly after the last flush, not sure where that is coming from though.
and i currently has the stock clutch fan and shroud with what i assume is a stock thermo fan (not too sure on that it might actually be on the ac but i've never seen it kick in before it actually starts to overheat) which now that i type this seems a little strange, the a/c getting warm is the first sign in the car that it is starting to overheat which might be the thermo kicking in.... i have no idea now.
Edited by joseph0205
Get the Worley one if you're not making massive power. I used to track my car with that and was decent, until I starting making modest power.
Just file down the thermoswitch port down flat, they are always jagged and don't seal too well out of the 3 I've seen and installed.
5 hours ago, niZmO_Man said:
Reverse flush your radiator and flush your block and heater cores.
I recently flushed the whole system and it worked fine for about 3 months. i drove 8hrs straight one day about a month after and the temps were fine but i barely made it .5hrs 3 days ago without over heating on a rainy day. Could this just be really settled gunk somewhere in the engine?
And anyone else have opinions on Worleys?
I have also found a moshimoto for ~$460 shipped http://www.prospeedracing.com.au/products/mishimoto-nissan-skyline-r33-performance-aluminum-radiator.html
Or a fenix for $360
http://www.sprparts.co.nz/fenix-race-alloy-radiator-nissan-r33-r34-c34-c35.html
Not saying its the solution just yet but should i just go the cheap $150 worley (the car probably makes just barely over stock power, but i have possible plans to try to hit the 300kw marks so not massively stressing the car) or should i bite the bullet and spend the 2-3x more on a decent-ish brand now?
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
