Precision 6870 gen 2
Hey guys I'm new to forum and hope I've put this in right section
Has anyone used a precision 6870 on a rb30 and had goood results?
I'm thinking of going down the precision path as all I read is great things about the gen 2 range as far as peak power at lower rpm is concerned compared to other comparably sized turbos.
Ive always had Garrett turbos and was going to buy the GTX4294 just because the spool time would be a bit better and it predominately a street car. I am chasing about 500-550kw at the treads.
Many help would be greatly appreciated.
https://www.sau.com.au/forums/topic/469850-precision-6870-gen-2/
I'm not really hung up on any certain manufacturer as they all do great things for different setups. I'm more so trying to get a feel for precision and what suits the best turbo for my application.
From what I've read so far the 6870 is good for about 800hp at the tyres on a rb30 so I didn't think it would be a case of "over turbo". Considering 760hp is about 550kw.
6870 on 3L is your best option it's like a 6466 on a 2.6, you'll make the power of those smaller turbos and won't be working the turbo as hard (safer too)
it's 3L spool and torque is on your side
BTW i have a brand new 6870G2 if u like
  • Like 1
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
