Hi guys back again with yet another issue i have obtained a boost controller and have found i cant find a wiring diagram or a how to install for this controller. Its model is Hdi HYB-MAC-SOL and it seems a couple c wires are broken from the clips ive tried to find additional cable which are being sent to me from an ebay seller and still no diagram or how to found if anyone has any ideas please throw them my way...1491014431499.jpeg1491014528825.jpeg1491014576206.jpeg still new to turbo cars and i dont know if it makes any difference but it is for a 1993 R33 Gtst. Is there any way to fix existing plugs if not with the new wires and plugs il still need to know colours of what goes where.... any one????? Any thing???? Lol
https://www.sau.com.au/forums/topic/469854-hdi-boost-controller-issues/
Its an Aussie company.
Get instructions here:
http://www.hybrid-power.com/installation
or give them a ring   Australia :+61 2 9620 7388
Hey bro i received my replacement wires to day and have pulled the loom apart to ste things straight and have noticed that theis has been done before as now the colours are all over the place ffs.... emailed and called ans still to no avail was i able to pull up a wiring d iagram or colour chart thing :(
Your photo does not show exactly what you have but this PDF should help you.
It shows the colour codes for you main plug. Do you have the second plug that goes to the Mac Valve? The wires to the Mac valve can go either way round - its just a solenoid.
http://photos.imageevent.com/kadepunk/hybridinstallationguides/HDi SBC-D.pdf
You have the colours you need (plus some  wires you don't need)
You have the red, orange,green and I am pretty sure that although you don't have a blue the yellow serves the same function (goes to ignition).
The twin wire loom goes to the solenoid (Mac valve) either way round.
Thanks bro but thats the one i found and it has different colours if i knew the layout ofront right to left or left to right of the clours and what they do i could sort that out myself im just struggling finding a diagram whith the colours i have. :/
I decided to tidy up all the stereo wiring and I had seen a few people with Skylines had wired the controller into the stereo loom with no issues so I decided to do the same and soldered and heatshrunk all the wires and the controller is now fully installed and seems to be working fine.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
