19x10.5 TE37SL
hey guys just bought my self some 19x10.5 TE37SL just curios on what everyone else is running on these rims and in tyres specs?(if there has been a post made already sorry in advance)
cheers
Edited by OV33RR
That's an expensive set of nice wheels. Don't spoil it by putting stupidly narrow stretched tyres like some people do!
Something like 285 35 may do the job. If the tyres stick out too much make the guards bigger don't shrink the tyres!
  • Like 6
I ran 275x35x19 on my R34 GTR (work d9r 19 x 10.5 +15), which is mildly lowered. I couldn't go full lock without scrubbing on the inner guard linings on both sides.
I went down to a 275x30x19 tyre and used a heat gun on my inner linings. No scrub whatsoever now.
  • Like 2
1 hour ago, OV33RR said:
12+ is what my Te37sl are I ended up getting 275 35 19 all round on stock hight not to bad but scrubbing on full lock
How about some pics?
12 hours ago, IMACUL8 said:
love the car - but those tires look to small for those rims.
Im not a fan at all of stretched tires - especially on a GTR.
275/35r19 there pretty big dont think id like to go bigger scrubbing as it is
I understand - but then why go 10.5 wide if your not going to put the appropriate tire on there.
The below is 10 wide with a 285 - see how the sidewall is square - surely that will give the car better turning and handling - please someone correct me if I'm wrong.
  • Like 4
Then you could have got 9in wheels. Stretched tyres on a GTR just seems an abomination to me:down:
  • Like 3
  • 2 months later...
16 hours ago, vxsr33 said:
From what i have read 275 or 285 is the recommended width for a 10.5 inch rim. 275 on a 9 inch rim isn't recommended as its too wide.
275 on 9in wheels are within the LVTA guidelines but the proof of the pudding is in the photos - OPs tyres are clearly stretched and the above 285s on 10 in wheels look just right.
295x30x18 on a 10.5" wheel, Yokohama AD08R 295's recommended wheel size 10"-11"
Looks spot on[emoji106] I run 265/35/18 ado8r on a 9 inch rim and they sit similar to that.
  • 3 weeks later...
I've got the same wheels offset etc, previously I had 275/30 no scrubbing now I have 275/35 19's nitto nt05 scrub the inner and outer guard. Then again mine isn't ride height, I wouldn't go anything thicker then the 30 series unless u want to do some suspension and camber work. My front is at 3 degrees camber to prevent my guards ripping again.
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
