17311323_10158371858350506_7044602791897199440_o.thumb.jpg.15cfd7a80ac594b2ab32290748bc8344.jpg
Who doesn't like a private track day? especially when I'm part hosting haha... ironically the dose machine won't be there, I'll be sporting a Honda Type-Gay I mean R EP3 (not mine, will borrow it).
To join, please get access to this page:
https://www.facebook.com/groups/traklifegreasertrackday/
There will be prizes!!!
  • Like 1
at the moment we are nearing half capacity, with max of only 32 entrants :)
Most people do about 6~8 laps and get off so at most you'll wait around in the staging area for 5 minutes at most. By lunch time, everyone has run out of fuel, or blown their motors, etc...
You come!
Maybe if you come, it might motivate me to finish my car lol... in the past 2 months, I've managed to just sell my bottom end lol.
Update time for you starts.
95dB limit, I'm the dose king bitches!
Oh yeah, if you're a SAU Forum member, it's only  $200 for you. Just PM me so I keep an eye out for your registration. Unfortunately you must also come in a Skyline on the day.
If you register a Honda it will be full price :)
  • Like 1
14 hours ago, kingtube69 said:
Definitely tempted to come but I'm just returning from 4 weeks of leave so my boss may not be too impressed if I ask for more time off.
I'll setup your anti-lag :)
We are now offering pay on the day.. once again if you come in a Skyline of any sort you'll get a discount.
Sorry, R35 GT-Rs pay $250.. you're technically not a Skyline anymore (as per the very interwebs).
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
