GTR
R32 under bonnet mat, used good condition $50
R32 gtr ecu $100
R32 gtr knock sensor loom, discontinued part from nissan, new $150
R32/33 gtr coil pack ornament $100
R32/33 gtr exhaust manifolds $100
R33 gtr oem dump pipes $50
R33 gtr oem turbos $100
R32/33 gtr turbo inlet pipes, the cast alloy ones $50
R33 gtr oem front diff $100
R32/33 gtr fuel rail $50
R32/33 gtr tps $50
R32/33/34 afm's $100
R32/33 gtr CAS x 2, $100 each
R32/33 gtr coil pack set $100
R33 gtr alternator $125
R33 gtr complete cold side, inlet manifold, throttle bodies, plenum etc $475
R33 gtr coil pack loom, $75
R33 gtr balancer, $50
RB26 N1 block new, $4995
R32 GTST
Complete boot lining 4 pieces inc carpet $150
Boot lid $150
Type M rear spoiler $150
Type M front bar, professionally modified to fit and allow airflow to a large front mount $250
Type M brake calipers, front and rear $400
MISC
HKS super hybrid panel air filter, less than 200km use, suits all rb air boxes, as new $25
All parts located in Brisbane, please contact via pm only. Postage available at your expense or pickup on the northside!
Edited by Gts-t
https://www.sau.com.au/forums/topic/469901-gtr-and-gtst-parts-for-sale/
Forgot to add
R34 GTR
Oem intercooler $200
Oem bov's and all piping $200
All intercooler hoses $50
R32/33 GTR
Ignitor, painted back with fins sanded back a little for looks $100
Edited by Gts-t
Hey mate,
Is the boot lining actually complete? Seems to be missing the little door on the left for the jack and a piece off the right side trim too?
Cheers
Shit your right Jimmy, its not complete :( Whats in the picture is what i have, its been so long since ive looked inside the boot of a R32 thats not stripped i completely missed this. Ill see if i can find the other bits but I'm pretty sure they are long gone.
GTR
R32 gtr ecu $100
R33 gtr oem dump pipes $25
R32/33 gtr tps $50
R32/33 gtr CAS $100
R33 gtr alternator $100
R33 gtr complete cold side, inlet manifold, throttle bodies, plenum etc $450
R34 GTR
R32 GTST
Boot lid $150
Type M brake calipers, front and rear $350
MISC
HKS super hybrid panel air filter, less than 200km use, suits all rb air boxes, as new $20
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
