R33gtst2016 Posted April 9, 2017 Share Posted April 9, 2017 So I took intake pipe off the other night and found this under the intake pipe looks like a grinder handle Jammed in a pipe, but I got no idea what kind of pipe it is anybody have any ideas. Link to comment https://www.sau.com.au/forums/topic/469956-wtf/ Share on other sites More sharing options...
admS15 Posted April 9, 2017 Share Posted April 9, 2017 That is the bov to intake pipe plumbing. Previous owner has blocked it for the pigeon noises. Link to comment https://www.sau.com.au/forums/topic/469956-wtf/#findComment-7822986 Share on other sites More sharing options...
R33gtst2016 Posted April 9, 2017 Author Share Posted April 9, 2017 Wtf so there is ment to be a bov ment to be there. I've only owned this a few months and still discovering the dodgey shit the previous owner did. Link to comment https://www.sau.com.au/forums/topic/469956-wtf/#findComment-7823018 Share on other sites More sharing options...
admS15 Posted April 9, 2017 Share Posted April 9, 2017 Yes there is. Setup should look like this on the j pipe. Link to comment https://www.sau.com.au/forums/topic/469956-wtf/#findComment-7823020 Share on other sites More sharing options...
R33gtst2016 Posted April 9, 2017 Author Share Posted April 9, 2017 Yer I've got that I think you may be looking at the wrong pipe I put grenade dots on it this time but let me know if I'm wrong Link to comment https://www.sau.com.au/forums/topic/469956-wtf/#findComment-7823025 Share on other sites More sharing options...
R33gtst2016 Posted April 9, 2017 Author Share Posted April 9, 2017 It isn't a rubber pipe it's painted black Link to comment https://www.sau.com.au/forums/topic/469956-wtf/#findComment-7823026 Share on other sites More sharing options...
R33gtst2016 Posted April 9, 2017 Author Share Posted April 9, 2017 It isn't a rubber pipe it's painted black Link to comment https://www.sau.com.au/forums/topic/469956-wtf/#findComment-7823027 Share on other sites More sharing options...
89CAL Posted April 9, 2017 Share Posted April 9, 2017 Yes it is the BOV return line. It will go to the intake pipe (pre-turbo) and the other end should go to the BOV on the J-pipe (pre-throttle body) Link to comment https://www.sau.com.au/forums/topic/469956-wtf/#findComment-7823041 Share on other sites More sharing options...
R33gtst2016 Posted April 10, 2017 Author Share Posted April 10, 2017 Oh ok what would happen if I didn't re connect it ? Link to comment https://www.sau.com.au/forums/topic/469956-wtf/#findComment-7823140 Share on other sites More sharing options...
KiwiRS4T Posted April 10, 2017 Share Posted April 10, 2017 Your car will explode in a ball of fire. (Maybe not) but if you have a stock ECU your engine will run optimally with the BOV return plumbed back in to the intake. Otherwise the air measured by the MAF will not be the same amount as what finally reaches the plenum. If the BOV is simply blocked off this will not happen but then you may as well not have a BOV, Link to comment https://www.sau.com.au/forums/topic/469956-wtf/#findComment-7823165 Share on other sites More sharing options...
