Wiggins do allow for 8degrees of misalignment per clamp (4deg per ferrule) but in my case it doesn't really matter as I am running solid engine mounts [emoji1]
  • Like 1
3 hours ago, iruvyouskyrine said:
I don't do things by half measure, except for using a NIStune haha
Nistune is the best, especially with the feature pack and a R35 AFM
As a matter of interest Josh, what have you done for solid mounts?
Got my mate to spin up some custom alloy mounts that position the engine as close to the firewall as possible (10mm further back than standard R33 mounts would position it). Will find some pics of them for you.
  • 9 months later...
Wondering if there are any updates on this, would like to see a dyno plot lol.
Basically in my situation i'm looking for the same thing this guy is. I have a Hypergear SS1.5 and while it makes the power I want I find I really do need power 1000+ rpms earlier. I live in the US and do track and autocross and I find i'm doing autocross way more and I just am out of the power band constantly while when the car was stock I was fine.
I have a FD RX7 that I was going to keep stock but the power on that car if I were to just mod it with stock turbos would be perfect to me. I just want to NOT do that since a completely unmodded mint low mile RX7 is a rarity over here.
It took a lot of work to get the car running right up to this point and I don't want to replace the engine. If I have to do that i'd just sell the car and use the money from that and put it into the RX7. Which I don't want to do lol.
Hoping to see some results so I can make a decision.
14 hours ago, GTSBoy said:
RB25 fixes this.
Not necessarily. In my case part of the reason I want to stay RB20 is because in my autocross class I can run much lower weight with a 2 liter. Also there is another event I participate in that has a separate class for 2l turbos and above 2l. That is the cutoff. Above 2l is against modern V8 cars
There is another class at that same event I could be in for 89 and earlier cars but I would have to increase weight to 3200lbs.
RB25 would be inconvenient. It'sliterally the difference between me facing a C6 z06 Corvette or a S13
Edited by Kanaric
Change the rear end gearing.  Make the engine run in its happy zone.  RB20 requires revs.
  • 3 months later...
Finally everything is finished!.............................. Naht.
As is tradition with car builds right near the end i have decided to change a whole heap of things for no reason other than i felt like it. Luckily its really only the ECU and the loom that will be changing, all else will remain the same (with the exception of removing the ABS as the Link can't do that)
Long story short is that everything was in and running using the NIStune and the Garage 7 IPC. Tuned by Jez on 98 octane running 12psi it made 180kw and then went into the shed for the last 9 months as i had lots of other more important stuff going on in my life. Only running such baby boost as this is a 10.5:1 engine and its absolutely begging for E85 and 3x the boost.
To my surprise the car was disgustingly slow. Like honestly beyond belief slow, although this was all just driving around my street unrego'd so never really got up it. But i had forgotten to swap the diff out because it is terribly mismatched to the RB25 gearbox. Diff in it currently is a 3.6 and new diff going in is the more appropriate match for an RB20 being a 4.3 so that should make it feel quite a bit better i would hope.
Anyway tonight it will get new diff and rego so i  can put some KM on it and then in the next month or two it will get a full rewire, Link Extreme ECU, Plex MicroSDM 100, and as many sensors as i can throw at it. Then off for a full flex tune and hopefully enjoy it over summer!
  • Like 1
Post up a graph for this thing.  With only 12psi not that surprising it's making that sort of numbers.  Air mass flow requires some boost, and air comes free!
Gearing will transform the driveability.
  • 2 months later...
No graph but felt somewhat responsive on the street with 9 month old 98 octane in the tank. Drove it for one day and truck crashed into me and wrote the car off. Probably no new updates for a while.
  • Sad 2
  • 1 year later...
Omg gutted the car was written off? Still no updates to this?
On 21/11/2018 at 10:55 AM, iruvyouskyrine said:
Nothing has happened for a while but it kicked off again recently. Will be same same but different. Complete PRP and MoTeC catalogue thrown at the car. Will keep you updated
  • Like 1
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
