25de+t head on 26det block
I got an r32 gts recently. its a bit of a Frankenstein project in that its running an RB25de+t head(08U) on a RB26det block(05U). A gtr ecu untuned Im assuming, & gtr injectors. When I first got it, it was running real rough & would only start aided with engine start. I couldnt find a resistor pack in the loom so I peeled it open & found that someone has wired 10w10ohm resistors inline on each injector. So I got an OEM gtr resistor pack & wired it into the loom now it starts like it should but its still running rough. It idles fine & slowly rides off in first ok but as soon as I give it a bit more gas it coughs & misses. Im just looking for some advice/input/interest in this thing to keep me motivated on getting it running right.
https://www.sau.com.au/forums/topic/470001-25det-head-on-26det-block/
I'd suggest taking your car to a tuner.
Certainly sounds like a mess. I can't see anyone diagnosing something like this online without viewing the car.
25de+t head doesn't make sense to me, It'd be just a normal non turbo head correct?
  • Like 1
I agree with jmknights92 - I would also invest in a wideband too, check what those AFRs are doing.
Yeah 08U series 0 rb25 i think
    • I love my R32 interior but then I also love the generic 90's nissan vibe from R33s/S14s/Pulsars etc 100%
    • I have seen this happen in cases like the R33 GTR where they eliminated the ATTESA actuator rod retaining clip to save 5 cents. Parts diagram references it, the actual part doesn't. Also if you try and look up the specific retaining clip on an R33 GTR it resolves to nothing. But it exists on R32 GTRs as I discovered a week or two ago.
    • Where is the electrical conduit? 馃ぃ馃ぃ
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
