Some one ask me what a TD27T looks like in a R32
So some one got a little drunk and made a bet that a TD27T in a skyline wouldn't be sick........
so here's the project so far just because I wanted some were to share my progress ;)
started off with a Hcr32,hicas all removed and swapped out with factory non-hicas lines and subframe, welded diff, as much weight removed as cheaply as possible 700kg chassis as it sits without a motor.
picked up a factory as frig TD27T out of a terrano, 2WD Navara turbo gearbox and a S14 SR20det cross member.
Not sitting in her final resting spot yet. Just waiting on engine mounts to turn up. But hopefully over the long weekend I'll get some more done ;)
  • Like 3
It won't rev like a 20 but if it smokes a set of tires at idle then I'll be happy as a pig in sh*t...
so update : SR20det crossmember with SR20det engine mounts bolts straight into a r32 ( I didn't not know this haha )
td27t with the 4x4 engine mounts bolt up to factory SR20det mountings.... its like Nissan wanted a TD in a Silvia.....
So i have a issue. Between the crank and steering rack I have say 30mm of clearance.
This shouldn't issue me except for the fact the sump is getting cut the f*ck up.
the RWD sump I have not much of it will be left except for the rear section the oil pickup goes in.
If I use the 4x4 sump I'll have the big dropper at the back.
is there a don't make your sump smaller than this guideline?  Or am I just over thinking issues?
ahh, here:  http://www.caradvice.com.au/506503/nissan-australia-secures-future-for-local-manufacturing/
A small Kangaroo cast into the finished product identifies all the components cast in the Australian factory.
I hope this thing is going to go down the path of some of those Euro diesel drift boy setups (Benz, BMW).
Give it a big turbo, 50psi boost and plenty of fuel.  Still won't rev but ought to make enough torque to screw clutches and gearboxes with ease.
Watching with interest.
Edited by Dale FZ1
got given a Garry turbo the other day off a 13b. Exhaust housing is tiny. Intake is a little bigger than A/R 50...
and I'll slap my Nisbro 1 way ARC diff back in once she's road legal ;)
th kangaroo subject is rather interesting.
I forgot to to say why I came back on...
motor all bolted down clutch is on.
Waiting on top mount turbo manifold and intercooler to turn up.... gearbox going in tomorrow.
power steer lines have to be cut.
power steer pump relocation to divers side to suit TD mounts. Lines a lot shorter. Fluid tank moved to battery location.
4x4 sumo clears the rack... needed some encouragement with a 20oz hammer tho.
Starter mould on bell housing extremely close to fire wall... 20oz hammer. Problem solved.
15 hours ago, XRATED said:
This needs a 100hp shot of nitrous/propane mix.
f**k yes......
11 hours ago, Dale FZ1 said:
Amazing what a hammer can fix.
Mate a hammer is the on,y thing that can fix stupidity.
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
