Brake pads for Skyline V36 sedan
Ive spent a few days on here trying to work out part numbers and what pads to get for our 2007 Skyline v36 sedan type S.
I thought this would be simples as the type S and the SP have bigger brakes than the type P, but there are different types of model numbers and different info out on the net...
Any advice or info ?
Ive attached a few pics, I didn't really want the hassle of jacking the car up, pulling the pads out to take photos of them and then putting them back in with the old pads. First photo is front, other two is rear
Edited by R377
dfdff
https://www.sau.com.au/forums/topic/470009-brake-pads-for-skyline-v36-sedan/
6 minutes ago, The Max said:
Those calipers don't look like a type S at all. Then again, my knowledge of anything pre-2009 is very limited.
some websites say 06-08, then 09-onwards are different
Some sites say V35 non brembo and v36 pads are the same.
Some say suit most PV36 and some KV36.
All very confusing
The early sedan's have large single pot front calipers running a 330x32mm rather than the expected twin pot caliper on a 320x28mm disc.
This means different front discs and pads.
The rear discs are also different sizes, bigger on the old cars, but seem to be the same pads... I have attached some data from the Infiniti service manuals.
Give Brakes Direct a call, they have pads for both fronts, but currently only the smaller front discs.
  • Like 1
I just bought some for my Coupe today.
I found this thread which i used to find some
Fingers crossed they fit my my car.
I've had trouble finding the right ones.
Coupe
Sedan
Sports
Sports Premium
Brembo
  • Like 1
3 hours ago, nickcorr said:
No Brembo's on a V36.....
However, depending on which year model, can often be confused with the 370Z, which is specified to have Brembo. For example, the DBA 4000-series discs I bought for my 2009 V36 are tagged as being suitable for the Brembo-equipped 370Z.
With all these terms being thrown about, it's no wonder people get confused. I can appreciate that.
Safest thing I would suggest to Mr. R377 is to measure those discs and use that as a point of reference for which pad he needs. That's how I determined mine. Measured, looked them up in the workshop manual and then ran from there.
  • Like 1
Thanks for that link - those pads look the same as mine.  Maybe the 2006 and 2007 brakes are different to the 2008 brake pads.  It makes it hard looking online in australia as soon as I put in 2007 skyline, it automatically selects the V35 and not the V36 skyline.
Here are pics of my pads and brakes.  Discs / rotors are 330mm by 32mm thick.
For reference our car is 2007 Skyline type S. From what i believe it is an type S as it has cloth interior, no reversing camera/sat nav, has the bigger brakes with the 18" wheels.
The type S and SP share the same bigger brakes with the 18 inch wheels.  The type P has smaller brakes with 17" wheels.  The type P has the all leather interior and BOSE stereo I think ? I think maybe the suspension is different on the type P vs the type S and type SP. The P and SP both have leather interior with heated seats, while the S gets the cloth interior.
On 13/04/2017 at 9:58 PM, qdhung said:
i got bendix pad for rear , but the front took me awhile so end up with ebc red. check my image for info
Thanks for the info Hung, those EBC reds look the same as mine.  Have you got any photos of the actual pads out of the box ? (just so i can be 100% sure before ordering)  Where did you buy the EBC from please ?
I forgot to add, the pads are from Intima brakes, a few guys on this forum run Intima brake pads.
From what I have seen the 1509 rear brake pads are quite common and universal, the main problem us Skyline owners have is getting the front pads correct.  I don't know if the front pads listed from Intima are for a coupe, or 2008 onwards sedan, or even a type P sedan ?
Sorry im not sure exact figures all i remember it took me awhile to get the corrected pads :)
also i got pad from shop called BGT in victoria
Edited by qdhung
more info
  • Like 1
  • 3 weeks later...
Thanks qdhung for the info.  I thought i would just double check with EBC directly
Those front EBC brake pads are DP31807C
The front rotors are D7459 (RK7459 in USA)  from EBC
From what i think the brakes from v36 sedan 2006 to late 2008 are what me and qdhung have, I think in late 2008 the v36 skyline sedan then went to the 3.7L with 7 spd auto.  I am guessing they changed the brakes then to the Akebono  calipers ?
These are the two brakes that were fitted on the V36 sedans from factory. The 3.5 and earlier 3.7 to at least 2009 MY (my car) run the 330 mm disc and single piston calipers. The later cars, maybe from 2010 when they had the facelift and proper foglights, got the 320 mm disc and 2 piston calipers.
No Akebonos from factory on the V36 sedans.
  • Like 1
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
