Rb26 single turbo. Does anyone know if i can re route a coolant line from the first pic under the intake manifold at the back.Around the back of the head to second pic at the back on the exhaust side of the block. Theres 2 holes the top one is my water return from the turbo. Can i tap into the bottom one. Any help would be greatly appreciated. 20170413_191536.jpg20170413_191609.jpg
https://www.sau.com.au/forums/topic/470011-rb26-coolant-line-re-route/
If the turbo is water cooled then the water return goes to the manifold fitting and the hole in 2nd pic is plugged. If turbo is just oil cooled just plug up both holes.
I noticed in the 1st pic you have the oil pressure sensor hole plugged up, you planning on having any sort of oil pressure monitoring?
  • 1 year later...
Interested in the outcome of this question. Gone single turbo, and no longer need a rear turbo return, only the front return. Every normal after capping that rear fitting? Is that fittings only function, the rear turbo water return? I see that it tees into the heater tubes as well, is this a coolant path for closed thermostat operations as well? Thanks
1 hour ago, WantGTR said:
In the first pic, block off that barb.
Second pic, use that and use the fitting off the top radiator hose water outlet.
If just oil cooled. Block all water fittings
Thank you for the response, this is what I was hoping for. I assume that means the 3/8” nipple on the heater pipe below gets capped as well? This is what confuses me, had it been just a return path for turbo coolant, I’d have no question to cap. However, that 5/16” nipple on the bottom of the plenum tees into the “behind head tubes”, which then terminates in the heater pipes. That is why, I was thinking it was more than just a turbo water return, and more of a closed thermostat bypass tube. For cold startup or something. I trust you that it can be capped, as others have said the same, I was just hesitant. Attached is a pic Which you can see clearly the hoses, and nipples I am referring too.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
