350+KW RB25 Package- bulit motor, turbo, ecu, intake and cooling system
Selling the engine setup out of my sil80 to fund another project.
Engine was built by Red R Racing in 2010 and I purchased it off another forum member in January 2012 with 1500km on it.
I have since removed the head and put on another one with a lot of port work and nitto head gasket in August 2015 by East Coast Customs in Brisbane.
Engine has less than 7000km on it as the car sat for long periods due to work. Has always been serviced with either Motul or penrite oil, changed to full synthetic when i had it tuned on flex fuel.
package will come complete with Engine, Intake, Exhaust side, mounts, loom & sensors, hardrace engine mounts, oil cooler, radiator (suits s13/r32) and header tank and Exedy ceramic puk clutch.
for any more information PM me and i will give you my phone number to call
Will not part anything located in Townsville QLD
$13000ono
Engine made 310 kw @20psi on 98, 365kw @26psi on E85
engine:
Mahle pistons
spool rods
arp bolts and studs
balanced and grub screwed crank
nitto oil pump
larger sump with baffles and 2 -10 ports
head drain
tomei poncams 256 degree
tomei valve springs
ported head
ross balancer
partly grout filled
oil restrictors
metal headgasket
ross balancer
Greddy plenum with Q45 throttle body- ceramic coated
6boost manifold- ceramic coated
gt3076r- ceramic coated
60mm turbosmart gate
all lines braided teflon
3 inch stainless exhaust
42mm radiator
headertank
mocal oil block with thermostat
setrab oil cooler
RB26 engine covers- powder coated
Mines cam baffles
ECU & Fuel:
1000cc injectors
nismo fuel reg
gtr fuel rail
Link G4 ecu- ethanol, fuel & oil pressure sensors
Techedge wideband
Edited by robbo_rb180
spelling mista
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
