CTS-V calipers
Hey all,
Heard quite a bit about folks swapping CTS-V 6-pot calipers into their S13s for a stupidly low price but am yet to hear of anyone doing it to a Skyline. I was interested in some 4-pots for my GT so hit up a guy who does custom adaptors for the S and Z chassis (http://www.ctsvbrakeswap.com/nissan/), he claims the S13 style adaptors should fit the non-GTR model R34s at least. Anybody got any more info on this type of swap/heard about anyone who's done it?
Cheers
It would seem silly to have to buy both adapters and the calipers that they suit from the US, no?  Or are these Cadillac calipers the same as some Holden/HSV ones?
Easier, there are Sumitomo 4-pot calipers that will just fall onto your car, at 310mm.
GTSBoy, yeah apparently they're the same as the SS Redline's calipers we get here, though for whatever reason the prices don't quite seem to match up between the two.
iruvyouskyline, I did take a look at that thread, it being the only one on SAU to actually touch on the topic. Unfortunately nobody on that thread ever seemed to reach a definitive answer as to whether or not the calipers could be easily applied to our Skylines. Being a GT owner especially, nobody really bothers too much with my model, with good reason honestly. So I was mostly interested in the accuracy of the guy's statement when he said their S13 adaptors could be used on my GT. If not, f**k it, I'll grab a set of 4 pots from a 33 or something and save myself some headache. Just thought with the CTS-V's being newer and in a lot of ways cheaper it'd be worth bringing attention to.
GTT brakes have 14mm bolts.  Do the 34NA brakes also use 14?  Or are they 12 like the earlier cars?  If 12 then I can't see any reason why you couldn't use any brake part intended for R32/3 or S13/4/5.  They're all basically the same dog at the hub level, number of wheel studs and different original rotor thicknesses notwithstanding.
I've heard conflicting things, some people say 12, some say 14, others say the series 1 models had 12 while the series 2 had 14. Again, probably why nobody really bothers with these cars, way more info on the turbo models. I was reading a post about some guy fitting G35 calipers to his GT saying he had to drill the bolts out from 12 to 14 though so I'd say it's a safe bet they're 12mm. With the disks being considerably larger, would I have to flatten out the surrounding rim to accommodate the increase in width?
Yeah sorry that is what I was talking about, cheers. So assuming I can confirm that the GT has 12mm bolts I might actually go ahead with this in the near future, I'll be sure to keep yall posted on the results. Cheers for the help fellas.
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
