Kebabs and Cars, 29 April 2017 @1730, Nandos Vic Park, Cruise to the Meet
Morning All ,
Trev from the left ? Martin red , Craig ( Martin's Brother) and Inari the young bloke - you've met him before the last up hill meet :) and next to my right my darling Jellybean [emoji594] Hahahahahaha
Sunday 7th May
Garbin Estate Wines
209 Toodyay Road
Perth, Western Australia 6056
11am to 2pm
R33's only meet and cruise
Sausage sizzle and drink for $5
Wine tasting and coffee available
Send me some more details or if there is a Facebook page.
I'm keen and I'm only down the road in green mount
Hahaha!! Girl power. [emoji23][emoji23] I live in Gidgegannup so far away! When's the next kebab? I'll jump on wasteland and check it out.
Just up the road from me I'm in greenmount.
One of the best roads to drive on around the corner O'brian Rd @shoey85 perhaps we should make a map and go for a cruise some time soon before it starts to rain
  • Like 1
its a Perth33"s meet Craig. its on facebook, just search. that's pretty much all the info there anyway.
That's my mates black R34 GTR in the showroom at cars and kababs, its gorgeous
Edited by Pal
upload pic
  • Like 2
One of the best roads to drive on around the corner O'brian Rd [mention=143902]shoey85[/mention] perhaps we should make a map and go for a cruise some time soon before it starts to rain
Sounds like a plan :)
  • Like 2
    • Correct, I didn't put GT-R in the same category in this thread, incase I offend anyone. But @GTSBoy  knows my true thoughts on all Nissans.
    • Get more oil pressure sensors. I have 3 purely because trust no-one. It would be worth checking (if not already) if it happens on every shift. Like boring, 2-3 shifts at 60kph making 10kw with no obvious G-force on a shift with mega power. Does it still drop? Does it drop less? What if you shift at 5000rpm or what have you with no load?
    • Unless things that you want to do include reference to time. Simple Boolean logic is only good for digital inputs or analogues that have been thresholded into digitals. But unless you also have a timer function available (which would more ideally be located inside the program, rather than being forced to implement a timer outside the ECU and bring it in as a seperate digital for every time delay you want to implement), then you can't do some of the things that you might want to do. My PLC ladder logics are obviously littered with program blocks, because that's easier than building it all in ladder gates, but the most frequent of those program blocks is a simple timer, because you actually can't otherwise do that in ladder at all.
    • Log voltage. I'm suspecting the alternator. Or even maybe a bad earth somewhere. ie, seeing as it is rev dependent, I am thinking it is alternator dependent.
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
