RB20 ECU power info needed
Hey all,
Went to test my ECU was working for my RB20 into S15 swap today and was unable to get consult working.
RX,TX,CLK all have continuity and are correctly pinned in the consult plug. Consult also has 12v and earth.
A little probing revelaed that the ECCS relay is not triggering, i have 12v on both sides of the coil with the ignition off (which is correct as per the nissan r32 servcice manual). I believe the ECU is supposed to switch and earth on pin 16 (ECCS Relay) when it turns on. So lets check if the ECU is turning on.
Pins 50 and 60 (ECU earth) both have a good earth.
Pins 49 and 59 (ECU pwr supply) both have 12v with ignition on
Pin 58 (Battery pwr supply) has 12v battery constant
Pin 45 (Ignition switch) has 12v when ignition is switched on
If all my power and earths are good then the ECU should be turning on? But yet i can't connect via consult and it's not triggering an earth on pin 16 (ECCS Relay) and triggering the relay itself. As my ECU has a NIStune and NIStune flex fuel board fitted so the little LED's have been removed, so unable to tell that way.
Will be checking it all again tomorrow but just after any ideas on why it seems the ECU is not turning itself on.
Thanks
https://www.sau.com.au/forums/topic/470136-rb20-ecu-power-info-needed/
Got a spare ECU? Sounds like everything is working ok so perhaps an ECU fault. Checking against a known working ECU is a quick and easy way to rule this out
Seen as the ignition key should be the trigger for the relay (to earth the ECCS coil side), it should activate it
Also check your fuses. I know my R33 has 2 engine control fuses and one of them (if installed) makes the car stay on even with the key out so maybe something silly like this?
Switched with a known working ECU and still a no go. Did some more investiagatin (using R33 manuals which were a little more clear) and it had pretty much the same troubleshooting info. It did say to check the ignition system (pins 10 and 20) and the injector (pin 107,108 and 116) earth points. The injectors i figured i didn't need those pins earthed as the actual injector signal pins pull to earth to activate the injector. And the ignition system i wasn't going to earth through the ECU as i am using yaris coils and was going to delete the ignitor.
Turns out that they all need to be earthed for the ECU to be fully working. As soon as i connected 10,20,107,108 and 116 it turned on fine and fuel sprayed everywhere in the engine bay as i have the fuel line disconnected and the pump started priming haha.
So for future reference, don't just disregard the nissan manuals (even if they don't make complete sense sometimes)
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
