Electric Turbo
Interested to see this:
The use of a 48V system also allows engineers to fit on an electric auxiliary turbocharger (eZV)  that could spin up to 70,000rpm within 0.3 seconds to deliver an immediate throttle response and zero lag.
Full article:  https://www.carsguide.com.au/car-news/next-gen-mercedes-engines-bring-48v-electrics-and-the-return-of-the-straight-six-46903?utm_source=taboola&utm_medium=msn-australia&utm_campaign=taboola_alwayson_desktop
and how long will it be before we start tearing out our exhaust gas energy turbines and installing a 48v electric one?  It could be a game changer.
https://www.sau.com.au/forums/topic/470167-mercedes-electric-turbo/
I remember reading something about an Audi (that's already in production) using a one - but to spool up a conventional large turbo; I think it's a great idea and good approach to use both technologies together until electric just takes over replacing the entire power plant.
This will be a version of the formula 1 hybrid technology. Turbo is still a turbo but uses an electric motor to assist. And it sounds like effectively a generator/motor harvesting electricity and deploying it when required
If you havent already, check out formula 1's V6 hybrid engines
I'm actually working on an engine equipped with one. The engine is still being installed in the engine bench as of now. We won't test the electric turbocharger before long.
These turbos need to be cooled via the engine coolant or via a low temperature circuit, and with the power cables, the plumbing etc... and the fact that they're small unit for now only aimed at spooling small turbo they're still very far from being properly sized for our kind of engine/usage.
But some manufacturers are working on 12v variant of these babies, you just need big ass wires to feed them. And we still need a control unit or an aftermarket ECU which can control them, an heavy battery to take the shot when the turbo kicks in and a powerful alternator.
Way too much modifications for now to be worthwhile but 10 years from now who knows ?
  • Like 2
I got 3.8psi out of a 12V system running on a RB25det engine with a electric turbo that I designed for a Chinese company in 2011. There are way better motors today I think I can get it to make around 7psi if I'm doing it all over again this year. Boost was instant spinning up a T04Z compressor once activated. I guess it can be attached to a turbine shaft to make it hybrid. Just don't know whats the reliability of the electric motor on long run.
  • Like 1
super keen to know how you go with the next round of testing....  hope you test it on the torque black hole- rb20det :-)
Cheers
J.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
