NAB 8 Posted April 24, 2017 Share Posted April 24, 2017 (edited) R34 GTR - Misfire/Stuttering Hey guys, Over the past couple of months I have noticed an increase in misfires while coming on boost/just before boost. Initially it was mild yet when it happened the 4WD and A-LSD error lights would toggle on in most cases. Now every time the car is driven I experience the misfire. The coil packs and spark plugs were swapped out for new ones just under a year ago so my initial thought was that it could not be them. Boost is also very inconsistent in when and what boost it hits. I also noticed that in 2nd gear for example, there is barely any boost (0.4-0.5 bar) before 4.5k rpm and then at around 5k it hits really hard (1 bar) and causes the car to jolt suddenly. I do know that the stock turbos currently installed are in poor shape having a whining noise so I wasn't sure if that had anything to do with the problem but I am planning to swap the turbos out next week hopefully. Has anyone had something similiar or know of a fix? Thanks, Nick. Edited April 24, 2017 by NAB 8 Link to comment https://www.sau.com.au/forums/topic/470172-r34-gtr-misfirestuttering/ Share on other sites More sharing options...
JGTC Posted April 24, 2017 Share Posted April 24, 2017 (edited) Have had similar issues in the past, whistling/whining sounds coming from the turbo can be bent/chipped fins or just faulty/split vacuum hoses, both can cause issues with the AFMs which in turn can cause the car to run funny. Before removing parts, take it to your tuner, have them perform a 'check up' on the dyno, where they can hook it up and diagnose before removing anything as well as a smoke test to test all the vacuum hoses/lines, faulty turbos can deliver inconsistent air causing issues with the AFMs which can cause the car to overboost, spike or miss. Best thing to do start cheap by doing a smoke test then move on to the dyno in a controlled environment to diagnose before spending money fixing unknown issues. Edited April 24, 2017 by squareznboxez 1 Link to comment https://www.sau.com.au/forums/topic/470172-r34-gtr-misfirestuttering/#findComment-7825702 Share on other sites More sharing options...
NAB 8 Posted April 26, 2017 Author Share Posted April 26, 2017 On 2017-4-25 at 0:39 AM, squareznboxez said: Have had similar issues in the past..... Thank you for the reply. That does make sense now that I think about it . I will get in contact with a tuner within the week coming and I have had air leaks in the past so I will make sure to inspect the whole system properly. Again cheers for the help, Nick. Link to comment https://www.sau.com.au/forums/topic/470172-r34-gtr-misfirestuttering/#findComment-7825953 Share on other sites More sharing options...
