R34 GTR - Misfire/Stuttering
Hey guys,
Over the past couple of months I have noticed an increase in misfires while coming on boost/just before boost. Initially it was mild yet when it happened the 4WD and A-LSD error lights would toggle on in most cases. Now every time the car is driven I experience the misfire.
The coil packs and spark plugs were swapped out for new ones just under a year ago so my initial thought was that it could not be them. Boost is also very inconsistent in when and what boost it hits. I also noticed that in 2nd gear for example, there is barely any boost (0.4-0.5 bar) before 4.5k rpm and then at around 5k it hits really hard (1 bar) and causes the car to jolt suddenly. I do know that the stock turbos currently installed are in poor shape having a whining noise so I wasn't sure if that had anything to do with the problem but I am planning to swap the turbos out next week hopefully.
Has anyone had something similiar or know of a fix?
Thanks, Nick.
Edited by NAB 8
https://www.sau.com.au/forums/topic/470172-r34-gtr-misfirestuttering/
Have had similar issues in the past, whistling/whining sounds coming from the turbo can be bent/chipped fins or just faulty/split vacuum hoses, both can cause issues with the AFMs which in turn can cause the car to run funny.
Before removing parts, take it to your tuner, have them perform a 'check up' on the dyno, where they can hook it up and diagnose before removing anything as well as a smoke test to test all the vacuum hoses/lines,  faulty turbos can deliver inconsistent air causing issues with the AFMs which can cause the car to overboost, spike or miss.
Best thing to do start cheap by doing a smoke test then move on to the dyno in a controlled environment to diagnose before spending money fixing unknown issues.
Edited by squareznboxez
  • Like 1
On 2017-4-25 at 0:39 AM, squareznboxez said:
Have had similar issues in the past.....
Thank you for the reply. That does make sense now that I think about it :). I will get in contact with a tuner within the week coming and I have had air leaks in the past so I will make sure to inspect the whole system properly.
Again cheers for the help, Nick.
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
    • I'd be looking at the mentioned EFR kit, room to turn it up if decide on e85 (which we know you will) and be super responsive and fun on the street. OR https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/?srsltid=AfmBOorrJa2S76JR5ekXprxBOtU44a1UProbe64YaiVi9zTVp1Lj814w And add whooshy noise for extra fun C5 corvette prices are coming down locally here and a mate has a manual one and is a heap of fun on the street and track.
