Recommendations: R34 Mechanic/Service Centre
Hey guys,
For awhile I've been taking my R34 to my local K-Mart Tyre and Auto for services (only because I used to know the store manager), but I'm kind of over their bullshit as lately they've been a bit dodgey.
So I am looking for a good mechanic in Sydney, preferably someone with experience working with Jap imports/Skylines.
I was reading around and found the attached thread from this forum, where a lot of people recommend seeing Mizu at JLM in Rydalmere. Is this still a good place to go? I don't mind travelling for it.
Thanks guys.
What part of sydney are you in / work around?  plenty of good workshops that can assist with general maintenance, as well as import specialists which can help troubleshoot particular issues and be more helpful with ordering parts.
I live in Western Sydney but work in the City, so anywhere between is fine.
Really want it for general maintenance right now, but the wanks at Kmart have caused an issue when they did my 100km service. They replace the timing belt and ever since there has been this strange noise coming from the engine bay, sounds like it's coming from the timing belt. I took it back to them to get looked at, and after looking at it for a day they told me it was because they wound the timing belt real tight because it was a sports belt and it would stretch over time and the noise would go. Well it's been 15,000km since then and the noise is exactly the same.
Edited by Akuma07
Around Blacktown there is Top Secret Imports, they have plenty of knowledge on imports as they bring them in, sell and service them.
https://www.facebook.com/TopSecretImports/
Also in Blacktown is J&S Automotive, i use these guys for all my cars, they are excellent troubleshooters for niggly problems
https://www.facebook.com/jsautomotiveblacktown/
In Fairfield there is Skyline Auto Works who offer both import spares/wrecking and mechanical work.
https://www.facebook.com/skylineautoworks/
In Castle Hill there's MRC Dyno & Performance who are excellent troubleshooters and engine builders/tuners
https://www.facebook.com/MRCDynoServices/
Some good mobile guys who deal with imports;
https://www.facebook.com/deviousautomotive/
https://www.facebook.com/jdmmonkeys/
Edited by squareznboxez
https://www.facebook.com/TransformanceMechanicalEngineering/
Give these guys a ring, they up your way in springwood, they look after everything from suspension, mechanical work to tuning, they are also dealers for MCA coilovers, could be a good one-stop-shop option for you.
Umm not to alarm you yet apart from being a load of shit it's also dangerous. There's factory specs for timing belt tensions for a reason and if it's to tight it will make noise and will also cause premature fail and if it fails you get to is piston to valve contact, meaning very expensive to fix.
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
