M35 Stagea Engine Light Help - long start, can't pull diagnostics
Hi Wagoneers,
long time lurker, first time poster hoping for some help.
Car: 2001 M35 Stagea (VQ25DET)
Issue: Long crank then start, check engine light, drives normal (possibly less power, i haven't tried flogging it)
I have searched all of the threads and tried to pull the codes from the CEL/MIL and I can't get the thing to flash for me.  I've tried 10 times and I don't think its because i'm not getting the timing right on the sequence.
I have the xanavian english conversion on the TV, was done before i bought it so not sure if that has prevented the stock display from showing any further CEL info.
I have a sneaky suspicion it might be cam or crank sensor but would love to pull a code to confirm / check if its still safe to drive to work/drop the kids without doing any damage.
any thoughts, ideas or even just a light ribbing from some veterans is welcome.
cheers
Adam
To get into the diagnostics, you have to do the sequence spot on, use a watch or stop watch, the timing is critical. Your fault does sound like a cam sensor, possibly crank. Once you get a code you'll know which sensor. Make sure you buy a genuine Nissan replacement. They are available from kudos motorsport for 110 each. Just replace the one that is playing up. No need to replace all of them.
Hi Peeps,
it turns out the lack of codes was my fault, I used a stopwatch and got it first go...
So the code was in flashes [10, 3, 4, 10] which i understand is 0340 or P0340 Camshaft Position Sensor Circuit Malfunction.
anyone know if its OK to drive gingerly around town until I can get any further with this?
thanks for the quick responses guys, kudos motorsports looks like the go.  Whats the easiest way to tell which side is faulty? (sorry i'm partial noob).  From reading i can see, possible stalling and hard to start but nothing major, would you feel comfortable to keep driving it until the part arrives?
cheers
Adam
Yes it's ok to drive, the car will be a bit laggy because the cams wont be advancing and it may also stall randomly which can be dangerous if you're not expecting it. Drive it cautiously with the expectation it could possibly stall on you.
Code p0340 is drivers side cam sensor which is the more difficult one to get to.
Thanks mate, very helpful and much appreciated.
cheers
Adam
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
