1965 Prince GTB(Skyline)
With my C110 project coming to a end the hunt was on for the next "project" and this Prince just happen to fall into my hands
This one is sadly missing the stock motor but with a Red top RB20 and 970kg weight should prove a fun car
  • Like 6
https://www.sau.com.au/forums/topic/470226-1965-prince-gtbskyline/
Car is not breaking real well so going to do Volvo upgraded.
There was some vibrations at 80kmph seems to be the tail shaft so going to do a custom one piece. When I jacked it up to check tailshaft found the fuel line runs along side the tailshaft so needs moving.
Not sure the LSD is working probably as well.
Then the motor has a bit of a miss, would love to get a intercooler of some sorts in there too will see.
New tailshaft in seems much better now
OEM prince rears only probably last this last change.IMG_4972.thumb.JPG.83df1ca3472096880b564b99ee27f719.JPG
New dual set up to work with the new Volvo fronts
Strange old school quirk the left hand side wheels nuts are left hand thread and right hand side right hand thread. I'm lucky I didn't snap a stud before I worked it out
  • 1 year later...
Nope it would not have been easy at all, my plan was to make a custom 3/4 triple core radiator and use the other 1/4 space for a small in intercooler. CB12ED95-6FEA-44B4-BD3C-7DE2D53B7B1F.thumb.jpeg.d51fe07c177210a2f5fde2222eb9ebe9.jpeg
but I decide to change the motor in my other car and will now be putting the motor out of it into the Prince DD911671-96F3-44DC-A86B-D8E6F00C6AE3.thumb.jpeg.1f8a18cae6bf98da8b536933660e0091.jpeg
this motor makes around 175-180hp mark so will be a little more the RB and make all the right sounds with the triple Webber’s
  • Like 1
  • 4 weeks later...
  • 4 weeks later...
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
