R33 Clutch master replacement tomorrow, pls help
Hey guys!
I'm not sure if this is the correct place to post but i need help.
See the thing is i need a clutch master cylinder and install tomorrow D: if anyone is willing to help it would be greatly appreciated! i'm don't know who to ask or where to go for advice. obviously i'm willing to pay for labor and parts.
The car is a r33 s1 if that helps and i'm located in Werrington, Sydney
Are you certain it's the master? slave is a more common reason for no clutch, or even a leak of some sort in the line.
Just Jap may have clutch master in stock and is open sat mornings, I'm not sure who else would have stock AND be open on the weekend. Ring first, it's a long way to go and find they don't have it. A lot of the guys are at Targa Tasmania today but I'm pretty sure the shop will be open.
In the meantime if you need to move the car you can (assuming the battery is healthy):
1. Put the car in gear, and then start it. It will move forward on the starter but should start running.
2. You can then drive in first gear with no issues. If you need to stop use the brake until the car stops and the engine stalls (then goto 1)
3. If necessary you can also change both up and down gears without the clutch.  To change up a gear drive up to medium revs, and as you take your foot off the throttle (which unloads the gearbox) pull the shifter to neutral at the same time. That's the easy bit. Then when the revs are about right for the gear you are after pull the shifter smoothly but firmly to the next gear. as a rule of thumb it will be somewhere between 2/3 and 1/2 the revs of the gear before.
4. Changing down without the clutch is similar but maybe unnecessary to get home. Lift the throttle and shift to N at the same time, then blip the throttle. When the revs are right (higher) for the next gear down the shifter will go in.  If you get either 3 or 4 wrong you hear a horrible grinding sound but it's not as bad for the gearbox as it sounds.
Changing the master means removing 2x 12mm head bolts + the clutch line. You should use a 10mm "flare nut spanner" for the clutch line rather than a regular open end spanner because it can round it off.  There is also a pin you have to remove that holds the clutch master's rod to the pedal under the dash. Also give the clutch line a good soaking in wd40 beforehand.
    • From there it is trickier. Ecutek seems to be one of those closed ecosystems where everyone password protects their tunes which means I either choose a tuner and can't change from them and can't make any changes myself for any reason, or I have to buy the tuning software (about $4k) and then get someone to tune from scratch (which is not simple with all the multi dimensional tables these days). Once you buy about 300 "flash points" per ECU you can get it tuned and add their "RaceROM" function which hacks extra functionality like launch control onto the ECU, and also makes extra data available for logging over CAN Not sure what I'll do there yet; I'm tempted to use one of the overseas shops that does billions of remote tunes of the platform instead of starting from scratch locally, a lot can be done online these days.
    • Can I log IAT eh? Well, can now So next thing was looking at data logging. Not straight forward because none of the motorsport displays have cracked the nissan/inifinti CAN and ECU based displays don't do g logging, lap timing, predictive laps etc.  So, I bought an Ecutek dongle from Tunehouse (Oz distributor). Even without a tune onboard that allows display and logging of about 50 parameters via Android (and presumably iOS) app. Approx 600 for the bluetooth + Usb version That gives me (pretty ugly but) functional dash display on Android And logging of these parameters I'll play around a bit over the break, but at least now I can make sure I have oil pressure when I get to some track testing.
    • I don't know what globes/headlight connector they run, but I'd be looking for a female adapter to plug into the existing headlight on one side. Something like this https://www.ebay.com.au/itm/256017245989 Then I'd use a pair of single input, double output relays (one for low, one for high), mount them in a spare space in the fuse box if you want to to look more original (and be easier to maintain). Then 2 new power sources from the main stud in the fuse box via a fuse to each relay. Low from the headlight adapter pin triggers low relay and high from the high headlight adapter pin triggers high and low. Earth the relays and new headlight sockets and off you go. Because it triggers off the original headlight all of the dipping/hi on/high flash all still works
    • I reached 10 posts and wanted to make my build thread too but still can't add pictures to posts so I have no idea how it works 😂
