membership details are still being finalised, soon we will be an official club, then you can pay the fees and become a member.
As for the cruises, check this section for details and rock up to the meets, easy as that.
By the way you have posted in the wrong area, should have posted in the Vic section, this section is for events only. :)
Cheers.
:rolleyes:
https://www.sau.com.au/forums/topic/47024-membership/#findComment-951700
Hi ICER33, Membership etc is only a short time away.
We have had our first official General Meeting
See this thread --> http://www.skylinesaustralia.com/forums/sh...ead.php?t=45933
So at the moment, all events are open to the General public.
Check this section (Events) at least 3 times a week and you'll see all the events that are going on in Vic.
There are events coming soon as the weather will start to get better.
Hope that helps. any more Q's just PM me if you like.
- ash
https://www.sau.com.au/forums/topic/47024-membership/#findComment-951772
  • 3 months later...
come to the meet on tuesday night with $50 and you'll get instant membership there. then you need to send off your cams registration form to cams with their fee of $90. Once all that's done, then you're set to go on the tracks.
https://www.sau.com.au/forums/topic/47024-membership/#findComment-1086161
Guys whats going on with SAU membership?
I've be asking for ages and no response.
I want to start track days and I can't till I become a member of a club.
Can someone get back to me on what I need to do?
you gotta read the forums mate.
There have been 3-4 general meetings... 1 cruise, and a number of other chances.
Its all posted weeks in advance for everyone sake.
until we get online forums up etc. Coming to a meet is the only way
https://www.sau.com.au/forums/topic/47024-membership/#findComment-1086209
Guest
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
