M35 LED high beam retrofit
Pretty happy with the M35 low beam. I just replaced the discharge lamps with some cheapies from eBay and they work a treat. So much so, that the high beam (H4 halogens) look pitiful. Has anyone replaced the low beam lamps with LED types? Which ones? I don't trust all the sellers on eBay to accurately quote the correct figures.
https://www.sau.com.au/forums/topic/470256-m35-led-high-beam-retrofit/
Most of the fleabay H4 LED (and more than a few of the arc discharge) retrofit kits are pretty much as good as their price would lead you to believe - terrible...
There are a few LED ones that I have seen for other vehicles that are actually decent performers but these are built using the same gear that you see used on a lot of high end Porsche / Audi vehicles and have the price tag to match. My suggestion would be to go for one of the quality brands - The Philips Ultinon ones appear to be be decent but as you have seen the from the wildly varying prices and claimed specifications that it is definitely a minefield and completely unregulated.
I replaced the low beam with eBay ones and they work very well indeed. That said, I checked the seller's rep and it all looked pretty good. The replacements (Chinese made) are significantly brighter than the 15 year old originals. So much so, that I now realise the standard M35 high beam is crap. Hence, I am trying to locate something to match the excellent low beam. I was wondering is anyone had actually replaced their high beam with LEDs in an M35 and which lamps they used. I want to know if there are any physical limitations inherent to some LEDs in the M35.
Edited by Zaphod
FWIW - I haven't used them on an M35 but I have used the H4 Philips for low and high beam on my daily and was happy with the results and its a similar reflector type to an M35 - there is a nice review with comparison pics on http://www.tundratalk.net/forums/tundra-lighting-electrical/603282-h4-philips-x-treme-ultinon-led-headlight-bulb-review.html and http://www.toyotanation.com/forum/61-tacoma-2nd-generation-2005-2015/1254065-my-opinion-philips-x-treme-ultinon-led-h4-headlight-bulb-review.html
I have found in the past from experience with a few kits that cheap LED kits give great light but its reliability where they fall over with a number of the kits I have played with either dying quickly or the lights working on a intermittent basis (although not nearly as bad as arc discharge ones). Your mileage may vary of course!
Edited by baron_von_bootsector
Additional link
Thanks for the links. The Philips lamps appear to be decent enough.
I bought a set of fleabay H4 LED globes, 9000 lumens. When they turned up they were only 4000 lumens. Got my money back. I fitted them out of interest, and found buzzing through the radio from the cooling fans in the globes. Bought a set of 55w HIDs, never looked back! Just saying.....
HID in reflectors, wow. Glare everywhere. LEDs, just as bad.
Look at Philips Racing Vision H4 or Osram Laser H4.
Also, H4 is dual filament, are you sure your M35 takes H4 high? Because H4 high beam only doesn't exist. Low beam discharge (a.k.a. HID), what did you buy? Don't expect them to last long (which is why you get Philips or Osram replacement, costly but you pay for the quality).
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
