Toyota Echo/Yaris Coil pack conversion for RB25DET
iMick
8 hours ago, Kraaken.r32 said:
Hi guys, been reading up on this as I have now bought some of these echo coil packs. I want to do this swap in mt rb20. Do I bypass the ignitor? If so how can this be done? Also is the wiring for the coils the same as rb25?
Yes you have to bypass the igniter. It’s done by bypassing it
ok great, is it a direct wire to wire? i cant find any info on that, do you normally just splice togther? if you know which wires need spliced would be great info for the thread
Hi Kraken,
I just completed this not to long ago on my RB20, what I did was identify what wire from the ECU fired what cylinder and then soldered that wire up to the corresponding plug on the loom. Another way to do this is outlined above by just pairing the numbers on the bottom of the ignition coil. But I recall there was an extra wire I had to do something with, I'm pretty sure it was a ground wire which I just paired up with the other ground wire that goes onto the coil pack holder..
Below is the colour combination of the wires for my stock ECU which may be relevant but double check yours..
54236697_2526481310712901_1661104337172037632_n.jpg.32e6bcde421a9886c06f9405e457e3ac.jpg
11 hours ago, Dylannn said:
Hi Kraken,
Thank you very much that makes sense! Thank for the pinout will help with future guys doing the swap as well as my self!
14 hours ago, GTSBoy said:
The wire that goes to the igniter for coil 1, now needs to go straight to coil 1.  I think you can work the rest of the pattern out.
Yes great answered many questions with that.
  • 1 year later...
  • 1 year later...
Just wondering will this conversion work with stock rb20 coils with changing the dwell timing?
I'm looking at doing this conversion as my coils have shit the bed, want to upgrade but I'm unable to change dwell with my current ecu.
  • 1 month later...
On 10/10/2021 at 6:04 AM, ganthercage said:
It is hard to beat RockAuto for these, at least for quality coils -- Denso, NGK, AC Delco/Delphi. Avoid junk. Denso is a major supplier to Toyota, and Toyota had a lot to do with getting the company off the ground and is still a big minority owner.
If DENSO makes the part then it's the OEM Toyota part - so buying it from a Toyota dealer is just a DENSO part in a Toyota box with mark up.
Any reason people are not running R35 Coils? They are generally considered best on the market and only cost $60/ea.
Yaris DENSO 6731306 - $52/ea
R35 Hitachi IGC0079 - $61/ea
PRP has a breakdown of the two coils in comparison.
https://platinumracingproducts.com/pages/r35-coil-vs-yaris-coil-debate
On 12/1/2021 at 2:57 PM, GTSBoy said:
People are using R35 coils. No-one in their right mind would choose Yaris/Corolla type coils. This thread is a hangover.
If we're going to revive a thread like this we should discuss the recent drama around this article: https://www.50ignite.com/blog/technical-blog/article-3-back-to-back-testing-of-370z-coils-re-co
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
