Power FC problems (sr20)
Hello guys, I am new to this forum. I am just your average 21 year old dude who bought a Nissan 200sx S13 with a SR20DET and I did some modifications. I assume this is gonna be a long post, but please bear with me. :(
So I started my car after 1.5 years and during those months I bought several parts. (Apexi Power FC Djetro, S15 turbo, 555cc nismo injectors and different things but that wont matter)
Anyway, 2 days ago I started her up and it went great, except for getting the car to idle. It just WON'T idle at all. I found out that my injectors had the wrong latency. I did 66% and 0.72ms and it should've been 66% and 0.10ms? So I changed that and after a few resets and start ups it went great.
First 10 minutes idle, amazing. 800-900rpm, car not shaking. Then I had to turn on the A/C which I dont have. I thought using the climate control and do some cold air would do the trick. Well I guess not. Car was doing weird things. 480rpm-900rpm over and over, here is a video; https://www.youtube.com/watch?v=GZXVeiSi1y0
I don't know what to do. :(  My map sensor and IAT are working fine. The car was idling fine but I had to complete te self-learning process. My defroster doesn't work either because some cables are missing. (I found some cables so I am gonna try it out tomorrow, it might work)
Other things that you guys might find interesting; My O2 sensor stays at 0.0v, even at idle. I found out today that there is a fat O2 sensor in the elbow, and the redtop ECU uses a Skinny O2. (I had a black top ecu, so this is why there is a fat o2 in there. Black top = fat o2 || redtop = skinny o2) Can it be because of this? How much influence does the O2 sensor have when it comes to the self-learning process?
Also, the car starts with boost control on. And I don't even have a boost controller. (I turned it off)
My mod list:
555cc nismo
gt28 turbo
Apexi Power FC D-jetro
Apexi powerfilter
aftermarket IC
HKS wastegate
Mishimoto rad
AEM Wideband (haven't hooked it up yet, I don't know much about this thing. But it was necessarry for tuners?)
Edited by Shirohige
https://www.sau.com.au/forums/topic/470267-power-fc-problems-sr20/
My thoughts are that it shouldn't matter if you don't have the stuff hooked up that would cause idle load to change.  Just get the ECU to learn through it doing nothing, and it comes out the other side not GAF about those things.
I concur on the O2 sensor & feedback being vital.  Once you get past cold start you need it working, or you need it tuned to ignore it properly.
6 hours ago, admS15 said:
Is the 02 feedback on? Same area where you turned boost control off. Can't you just do the idle learn procedure and not bother turning ac or demister on?
I can try. Yes, the feedback was on. All 3 or 4 times te feedback has been on.
Hmmm, ill try what admS15 said. If it won't work i'll look for another o2 sensor.
Yesterday the car had a really strong gasoline smell. I could even smell it in my exhaust pipe.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
