Hey guys, recently got my R33 S1 headlights retrofitted with quad projector headlights complete with white LED ring angel eyes and red demon eyes. I bought a used set of headlights with yellowing lenses for cheap and sent them up to Sydney to be modified by That Headlight Guy. Needless to say, I was very impressed by his work and the results are amazing. He does work on all types and makes of headlights and even headlights that don't come standard with projectors! Very friendly guy to work with, his attention to detail is especially helpful, he will keep you updated throughout the build process and will even offer headlight lens restorations! 5 stars and will recommend to anyone wanting to do any sort of modification and/or restoration to their headlights!
Here's his page: https://www.facebook.com/thatheadlightguy/
Edited by AeroZR
https://www.sau.com.au/forums/topic/470272-r33-s1-projector-retrofit/
5 hours ago, cul8er said:
Hmm I was thinking about doing this too what's the price ?
Depends what you need done. Additional angel eyes and demon eyes will add more to the cost, and how ever many projectors you need fitted will be taken into account. Extras like lens polishing and restoration will also add to the cost. Send him a message and he will be able to give you a quote.
  • Like 1
On 5/4/2017 at 4:24 PM, niZmO_Man said:
C'mon man, output shots of it fitted to your car :D
How are they switched? Selectable or always quad? Either way, huge improvement over shitty PnP kits.
Hahaha I'll get around to getting night shots eventually! She's been a major garage queen lately :P
They are direct plug and play into the existing headlight plugs. I had to install a relay kit on each headlight as the low beam and hi beam must both be powered at the same time for the bi xenon projectors to work - The standard plugs did not allow for this and when you activated the hi beams, you would completely lose power to all the lights. The relay kit fixed this issue completely. As for the angel eye LEDs, they are simply spliced into the parking light wiring and I wired the demon eyes to a separate switch in the cabin, powered by splicing into accessory (They only work if the car is on accessory or running but you can also power them directly from the battery if you wanted). They are always quad and the ballasts are simple to bolt in.
Edited by AeroZR
Ah so perma-quads. Mini H1? The Morimoto 7.0 is great width but the hotspot is typical H1 'spot' (which is one of the reasons I'd always go D2S over H1, bulb shim/quality is the main one). But running quad 7.0 should sort out that narrow hotspot "issue" haha. I hope you're running 35W on them.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
