Hey guys, recently got my R33 S1 headlights retrofitted with quad projector headlights complete with white LED ring angel eyes and red demon eyes. I bought a used set of headlights with yellowing lenses for cheap and sent them up to Sydney to be modified by That Headlight Guy. Needless to say, I was very impressed by his work and the results are amazing. He does work on all types and makes of headlights and even headlights that don't come standard with projectors! Very friendly guy to work with, his attention to detail is especially helpful, he will keep you updated throughout the build process and will even offer headlight lens restorations! 5 stars and will recommend to anyone wanting to do any sort of modification and/or restoration to their headlights!
Here's his page: https://www.facebook.com/thatheadlightguy/
Edited by AeroZR
https://www.sau.com.au/forums/topic/470272-r33-s1-projector-retrofit/
5 hours ago, cul8er said:
Hmm I was thinking about doing this too what's the price ?
Depends what you need done. Additional angel eyes and demon eyes will add more to the cost, and how ever many projectors you need fitted will be taken into account. Extras like lens polishing and restoration will also add to the cost. Send him a message and he will be able to give you a quote.
  • Like 1
On 5/4/2017 at 4:24 PM, niZmO_Man said:
C'mon man, output shots of it fitted to your car :D
How are they switched? Selectable or always quad? Either way, huge improvement over shitty PnP kits.
Hahaha I'll get around to getting night shots eventually! She's been a major garage queen lately :P
They are direct plug and play into the existing headlight plugs. I had to install a relay kit on each headlight as the low beam and hi beam must both be powered at the same time for the bi xenon projectors to work - The standard plugs did not allow for this and when you activated the hi beams, you would completely lose power to all the lights. The relay kit fixed this issue completely. As for the angel eye LEDs, they are simply spliced into the parking light wiring and I wired the demon eyes to a separate switch in the cabin, powered by splicing into accessory (They only work if the car is on accessory or running but you can also power them directly from the battery if you wanted). They are always quad and the ballasts are simple to bolt in.
Edited by AeroZR
Ah so perma-quads. Mini H1? The Morimoto 7.0 is great width but the hotspot is typical H1 'spot' (which is one of the reasons I'd always go D2S over H1, bulb shim/quality is the main one). But running quad 7.0 should sort out that narrow hotspot "issue" haha. I hope you're running 35W on them.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
