Cam dial in
Hey all, bit of  a brains trust question here. I have kelford cams that I have dialled in exactly to the specs I'm given, and my cold compression test is 170 psi. Was 145 with poncams. This extra pressure makes it impossible to tune. I have dialled them in to within 0.02mm of correct lift at 1mm degree point. At a loss as to why pressure is so crazy high. I'm thinking too much intake advance but it's perfect. Brainstorm please
https://www.sau.com.au/forums/topic/470279-cam-dial-in/
You have another problem somewhere.  170 is a good number. Tuner having a brain meltdown and missing something simple thats looking him in the face?
Are the cam gears vernier type or fixed? Need to know more aboutthe setup that was pre existing and whats there now.
https://www.sau.com.au/forums/topic/470279-cam-dial-in/#findComment-7827209
Hey guys thanks for the replies.
Basically I had specs for the wrong inlet cam. mine was custom made. So I dialled it in perfect (<0.02mm) and comp test was about 160 psi. Once I retarded my inlet 15 degrees and it was correct haha. Worked well. 600nm to redline and 400kw. It was never going to work with the old specs.
https://www.sau.com.au/forums/topic/470279-cam-dial-in/#findComment-7828439
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
