WTB - RB25DET Pipes
Hi Peeps,
Just chasing a few parts to get my vehicle back to a standard for roadworthy inspection, I have attached a couple of images of parts required. Maybe someone has these lying around after an upgrade.
Parts required - see attached images
1 x Water Tube Splitter Pipe - Location in image (Metal Tube Drivers Side Rear of the engine)
1 x Turbo Inlet Metal Tube Only
1 x Standard Turbo Exhaust Manifold - my current one has a big crack half way through right near the turbo flange area.
From my understanding with current items that would not pass inspection are the following as outlined in EPA document - Unroadworthy items list. http://www.epa.vic.gov.au/~/media/Publications/1031 4.pdf
1. Plenum Chamber
2. Aftermarket Throttle Body
3. BOV Atmospheric release
4. You can either have aftermarket intercooler or Pod filter - if you have both the Pod needs to be in Airbox
5. Dual Stage Boost Controller
6. Adjustable Fuel Pressure Regulator
7. Aftermarket Turbo that interferes with the standard emissions and is not an approved ADR replacement
Any info would be greatly appreciated - Luckily I have 90% of the parts to change over - just a few which were cut and re-purposed for the mods.
https://www.sau.com.au/forums/topic/470309-wtb-rb25det-pipes/
I may have this, but I need a better description - have a shit-load of pipes and fittings removed during a 25-30 build & have no idea which one you want. I may also have the intake metal pipe, but I cut something a while ago and it may have been that. Will have a look tonight, but if you get me a  better description (or drawing / photo) of the first fitting it would help.
Thanks Mate, its hard to explain that water splitter tube, I dont really know the exact name of it - there is an image at the top of the location of the metal water tube, its located at the driver side rear of the engine, and it is a metal tube roughly 25mm in diameter and it has 2 small metal tubes on each side of it which are roughly 10mm in diameter, so its a large tube which has 2 other smaller tubes coming off it. Its the only metal water tube on the drivers side at the rear of the engine that is 25mm in diameter and has 2 other smaller tubes coming from it. The tube is fixed to the side of the engine with a small piece of rubber water hose and 2 hose clamps then obviously another water hose attaches to it with the 2 other smaller water hoses. Wow hope that doesnt confuse you too much. Damn Nissan hah
So you are returning to stock for reg purposes and then putting the aftermarket stuff back on? If so, I can lend you the bits I have, exh mani, metal intake tube, I also have a stock turbo and exhaust system if required.
  • Like 1
Hi Champ,
Yeah I was offered a stock manifold in Geelong for a very low cost, however I am still yet to collect the item. Thats correct just getting all the stock things back on so I can get it roadworthy passed and registration done again. Then it will be all changed over again. Currently the vehicle is getting a new coat of paint and I am hoping to paint it within the next 3 weeks. 90% of the body is complete, just need to finish the rear bar and door jams then into the booth. After paint I will take it back down to Trent at Chequered tuning to finish the last tune. Then it will be all swapped back to stock. So I am hoping to have it all ready within 5 weeks for RWC Where are you located mate?
Mate thats excellent, I will certainly contact you when the time comes. Absolute legend as for exhaust and turbo pretty sure thats all good mate. I did cut into my dump pipe because it was custom already I simply cut the stock flange off and fabbed on the piece to take the new flange.
I will also look after you for helping me out and machine up a custom billet part, badge, what ever you like got some pretty nasty designs.
Thanks again
Is this the coolant pipe?
Hi Mate, yeah thats the pipe, coolant splitter. if anyone has had to change this pipe working on a complete vehicle they will know how frustrating it is to change or even tighten a hose clamp. Nasty pipe that one. Mine has corroded and split right where the smaller tube joins to the larger ones. I was thinking to just fab something from ally tube and then anodize it. But the thought of just getting something already available was much easier.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
