Just wondering if anyone has had issues with Proflow parts or Proflow themselves. So i bought a new Proflow fuel rail, to find the inside edges where burred and had metal shavings on the inside. After non stop ringing and emails for a month, today i finally received an email. Saying to just clean it up with a flat blade screwdriver!!!! Really isn't this why we dont buy cheap Chinese stuff. Anyway Im not bagging Proflow at all, I just wanted to know if this was just a case of 1 in a million. Thanks for reading, please leave a response if you have dealt with Proflow whether its bad or good
https://www.sau.com.au/forums/topic/470310-has-anyone-had-issues-with-proflow/
Don't think that's acceptable man seems pretty poor on there behalf, I've used them a couple of times and it's kinda hit and miss, sometimes the guys can't help you at all so you've just gotta know exactly what you need.
went in there one time had a guy spending ages trying to find the right fitting for me, said we needed to use some adapter and all up was going to be like $80 for a right hand bend fitting from like dash 5 to dash 6 the other side, I went to a place called "Enzed" and they had exactly what I needed for $10... and it had a psi rating too (Enzed is a hydraulic hose fitting specialist) I usually go there first before Proflow now.
Quality control issues and customer service issues, you can only really notify the company directors, if they are intending to operate their business successfully they will follow-up on your complaint, they need to be informed before they can do anything.  A company search and a couple of registered letters with photographs, will put the ball in their court.
...otherwise take your problem to youtube, and social media like Ravi suggested.
Well finally I got my fuel rail replaced from Proflow. Guess what this rail is as bad as the first one. Cant believe it. When I spoke to the person from Proflow on the phone, who was organising the replacement rail, he said he checked the new fuel rail. He said in these words. The new fuel rail isn't perfect but it sounds better than the one I have. Was i speaking to the guy from the scratch and dent section of Proflow
    • The more I think about it, the more I should probably go with a genuine Bride seat and rail set up. But damn the $$$ for a driver and passenger seat + rails!
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
